How To Flush-mount A Subpanel? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-28-2011, 06:17 AM   #1
Just call me Andrew
Rewards Points: 1,020
How to flush-mount a subpanel?
I am going to be installing a subpanel in the garage. Well, I just installed it, but I decided to flushmount it instead of surface mount to get it out of the way more.
How exactly do I do it? I assume I need to frame in a box as if I were framing a window. The panel would fit between two studs (square-d homeline), but that wouldn't give me any room tothe left or right to run wires. Also, I am concerned about running wires past the header above the panel.
One more thing, do I need anything behind the panel to prevent screws from the next room from accidentally penetrating the back of the panel? Luckily the other side of the wall is a place not likely to be screwed into, but you never know.
Just not sure the proper way to recess a panel. Any assistance would be great. Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 12-28-2011, 06:21 AM   #2
Julius793's Avatar
Exactly how you stated and you're right there will be no room on either side of the panel so all runs will have to be on top or bottom. Also you don't need anything to protect the panel
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 12-28-2011, 06:24 AM   #3
Just call me Andrew
SO I don't need to frame it in like I would a window? And I can just stick it between two studs? I am concerned I'll run out of room to run circuits if I cover all the side access.
What about getting through the header?
Andrew
Old 12-28-2011, 06:28 AM   #4
Julius793's Avatar
Oo I'm sorry I misunderstood you, yes you just stick it between 2 studs not like a window. Now in regard to the header of the wall you just drill a few holes to bring in your wire.
Old 12-28-2011, 07:49 AM   #5
Licensed electrician
Rewards Points: 1,486
The opening for the panel itself does not need a header. However, if the panel is mounted under a header that is already there to support the house you would bring the cables into the correct bay through the stud on the sides and then turn down to the panel.
Old 12-28-2011, 08:06 AM   #6
Just call me Andrew
But the panel is wide enough that i can't really use the side holes. What if I run out of holes on the top? Can I run more than one wire through a 1/2" or 3/4" hole in the panel?
Andrew
Old 12-28-2011, 08:08 AM   #7
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
Check the listing on the connecters, they usually allow more than one cable.
jbfan is online now   Reply With Quote
Old 12-28-2011, 08:12 AM   #8
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
If you're just installing this between two existing studs, you do not need a header. Plenty of room for wires.
tcleve4911 is offline   Reply With Quote
Old 12-28-2011, 08:13 AM   #9
Just call me Andrew
Do panels screw into the front of the studs? Or do I have to build out the wall between the studs to have a place to screw it to?
The reason i thought I needed a header was because I thought I would need to frame the panel into a space wider than the stud bay. This saves me some work for sure!
Andrew
Old 12-28-2011, 08:17 AM   #10
The screws go into the 3 1/2" side of the studs.
Old 12-28-2011, 08:17 AM   #11
jbfan's Avatar
Rewards Points: 386
Screws through the side into the stud.
Beat me by that much!!!
Are you covering the wall with sheetrock?
Old 12-28-2011, 08:28 AM   #12
Just call me Andrew
No plans to sheetrock anytime soon, but you never know.
Andrew
Old 12-28-2011, 08:35 AM   #13
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Make sure you set your panel to allow for sheetrock ...1/2" or 5/8"
Old 12-28-2011, 08:52 AM   #14
If the panel is narrower than the stud bay you can add a false stud to the one side.
Old 12-28-2011, 09:01 AM   #15
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
or if you need to come in from the side, you can cut 3/4" PVC pipe as a spacer and still have access to the side knockouts.........
flush mount dryer outlet bryan1282 Electrical 8 10-01-2010 06:17 PM
Surface Mount subpanel and 110/220 recepts - good idea? vsheetz Electrical 4 11-15-2009 10:29 PM
Flush mount an outdoor load center? wmldwilly Electrical 1 04-29-2009 07:17 PM
subpanel mount brmax Electrical 6 05-16-2008 10:48 PM
Flush Mount Ceiling Fans argana Electrical 6 01-05-2008 05:43 AM
