How To Fix Double Switch Controlling Two Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 12-23-2012, 07:42 AM   #1
Rewards Points: 214
How to fix double switch controlling two lights
Basement lighting I have flourescent fixtures plugged into outlets. the outlets are mounted in the 4" square boxes on the joists. two single switches on wall where each switch controlled an outlet. I replaced an outlet and then replaced the two single switches with one double switch.
Below is the wiring how do I complete this so that the bottom switch controls the right outlet and the top switch control the left outlet? Thanks
rosem637 is offline   Reply With Quote
Old 12-23-2012, 08:55 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
In the switch box connect the white wire to the bridged terminals of the switch. The white wire will become the hot feed and needs to be re-marked black. Connect the red wire to the top of the of the double switch, connect the black to the bottom.
In the right hand receptacle box, connect the red to the red. Remark the white from the switch black and connect to the black from the left hand receptacle box. Connect the white from the left hand box to the receptacle, connect the black from the switch to the receptacle.
Just a note: this will not meet NEC 2011 rules which require a neutral in all switch boxes. But this would require a new cable in your case.
Coastal South Carolina
Old 12-23-2012, 10:23 AM   #3
joed's Avatar
Rewards Points: 13,346
The white at the switches goes to the common screw. The white should be remarked with a marker black.
Old 12-23-2012, 10:52 AM   #4
Rewards Points: 214
Thats it got it working. Ok for the code violation for no neutral at the switch. Not to concerned never going to have a timer there. Is that the only issue with no neutral?
Thanks for the help.
Old 12-23-2012, 07:55 PM   #5
joed's Avatar
Since this wring is existing and only a repair it is grandfathered and the neutral is not required to be added.
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
wired new lights and now the switch turns off and on all my lights naty0629 Electrical 14 05-18-2012 12:03 PM
Help with Two Switches & Two Lights simplyphp Electrical 36 11-25-2010 02:47 PM
Dimmer switch is warm even when lights are off! gonzo Electrical 17 05-25-2010 07:10 AM
Wiring Outlets Then Switch Then Lights heydj Electrical 9 05-07-2009 08:09 PM
