How To Fix Broken Rechargeable Spotlight - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2010, 11:38 PM   #1
How to fix broken rechargeable spotlight
This is a cheap Radioshack spotlight I got several years ago. Forgot about it and haven't touched it. Now it completed quit.
How do I go about fixing it ? See diagram. I took the whole thing out and that's how it looks like. There are 3 free wires in the photo. The red and black connect to the red and black terminals on battery. The other free one with the screw is probably the ground, it was attached to the metal casing inside the light socket.
The left most dangler is where you plug in the A/C charger. When I connect the charger to it the LED light (on top) lights up, indicating charging. The middle switch with the spring turns on the off the light.
I didn't open this battery like I would have done with laptop battery since it says "Lead Acid Battery" so I assume it's toxic.
Could it be the light bulb or battery and how do I test it ? Can I test the battery with a normal electrical circuit tester or how do I make a bulb to test it ?
timcsi is offline   Reply With Quote
Old 01-15-2010, 07:57 AM   #2
The battery is most likely dead
I have one & the battery is dead, local stores a new battery for mine is $15
Old 01-15-2010, 12:14 PM   #3
Household Handyman
Rewards Points: 1,408
Dave is right about the battery, they are crap. Understand the people who come up with the idea of these "Fantastic" flashlight ideas shop around for the cheapest components to make them out of. The little electronic board you have with the red LED light and the resistors is your battery charger, they are junk also. These go bad and usually the red LED will blink fast. I have a one-million (1,000,000) candle-power unit my sister gave me which was wonderful when it was working. Then it went into the blinking mode when I tried to charge it. My battery was actually still good, the charger system was bad. I just by-passed the charger system, found me a cheap 2-amp charger to slow charge the battery. I had to use ingenuity to hook up this charger with the battery still in the case, but it works. Just my 2˘ worth, David
Old 01-15-2010, 01:53 PM   #4
How do I test to see if this battery is still good or not ? Where do I get the 2mp charger ?
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 05:27 PM
Making a patio from broken granit slabs need help BJLower Tiling, ceramics, marble 9 09-15-2014 12:15 PM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 03:18 PM
Frigidaire door hinge broken!!! bmgg Appliances 5 04-05-2009 11:16 PM
Broken floor flange for toilet billy Plumbing 10 03-13-2008 07:58 PM
