How To Finish Around 220v Receptacle - Electrical - DIY Chatroom Home Improvement Forum
Old 08-24-2014, 11:09 AM   #1
How to finish around 220v receptacle
I have this receptacle for the range, picture attached, that needs to have the mud placed around the outlet. Do I need to extend it out further, or just add mud on the edges? I can't find a cover other than the one installed. The outlet does extend beyond the wall about 1/8 inch.
How to finish around 220v receptacle-img_0240.jpg   How to finish around 220v receptacle-img_0241.jpg
ericjp is offline   Reply With Quote
Old 08-24-2014, 11:14 AM   #2
Rewards Points: 144
The installation of the box is wrong.
mako1 is offline   Reply With Quote
Old 08-24-2014, 11:33 AM   #3
What is the best way to correct the problem? I would like to have a flush mount, but am not seeing that type. I can redo the box or would an extender work?
Old 08-24-2014, 11:37 AM   #4
I have also posted this in drywall/plaster, but I thought I may also get input here.
Old 08-24-2014, 12:02 PM   #5
Rewards Points: 1,002
Like this
Anti-wingnut is offline   Reply With Quote
The Following 3 Users Say Thank You to Anti-wingnut For This Useful Post:
clw1963 (08-24-2014), ericjp (08-24-2014), gregzoll (08-24-2014)
Old 08-24-2014, 01:45 PM   #6
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by ericjp
I have also posted this in drywall/plaster, but I thought I may also get input here. I have this receptacle for the range, picture attached, that needs to have the mud placed around the outlet. Do I need to extend it out further, or just add mud on the edges? I can't find a cover other than the one installed. The outlet does extend beyond the wall about 1/8 inch.
You used the wrong cover, that one is for surface mounted, use a mud ring for flush applications, if you use a two gang mud ring, the plate will cover.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Kpack (08-24-2014)
Old 08-24-2014, 05:30 PM   #7
joed's Avatar
Rewards Points: 11,548
YEP, wrong setup. Box should have been mounted flush with the drywall and flush receptacle used.
Old 08-25-2014, 08:22 AM   #8
Thanks for the help. I did fix it correctly.
The Following User Says Thank You to ericjp For This Useful Post:
stickboy1375 (08-25-2014)
Old 08-26-2014, 01:31 AM   #9
You shouldn't double post.
Apparently, you already fixed it
Old 08-26-2014, 08:09 AM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
Originally Posted by Anti-wingnut View Post
Like this
For future note; typically these 4-wire receptacles need a 2-gang ring and place. In any case it is much easier to work with as well.
The Following User Says Thank You to Speedy Petey For This Useful Post:
stickboy1375 (08-26-2014)
switch for middle of run receptacle jpau00 Electrical 4 02-05-2013 05:20 PM
Unusual Receptacle Wiring Avanzi Electrical 5 01-20-2013 09:20 AM
Adding GFCI receptacle outdoors Dale Gribble Electrical 2 03-21-2012 02:18 PM
Using a multimeter to test a 50 amp receptacle WendyS Electrical 12 01-22-2010 09:10 AM
