Old 06-29-2012, 03:37 PM   #1
How to find junction box behind drywall
When we bought our house (built 2005) it had an unfinished basement. I took on the project of finishing it which I did. Now I want to add Directv in 2 upstairs bedrooms but I mistakenly covered the junction box for the Directv hook-up behind drywall. I have no idea where it is. Directv tells me I must find it for the tech.
Is there a way to find it without cutting out holes all over the place in the wall or ceiling?
Thank you in advance!!!
EdRaiders1 is offline   Reply With Quote
Old 06-29-2012, 04:03 PM   #2
Licensed electrician
If you can get your hands on a toner, commonly called a fox and hound you should be able to trace the wire.
Old 06-29-2012, 05:08 PM   #3
Master Electrician
Use a straight edge, such as a 4' level, to try and locate a bulge in the drywall.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
k_buz (06-29-2012)
Old 06-29-2012, 05:19 PM   #4
Any chance you took some pictures while you were finishing the bsmt?
Evstarr is offline   Reply With Quote
Old 06-29-2012, 06:52 PM   #5
Lic Electrical Inspector
electures's Avatar
Exactly what I would do.
All responses based on the 2011 NEC.
If you live in New Jersey click
. All other states click
Please check with local, county and state officials as laws may vary.
Sizing motors
. Online motor calculator
. Online calculators
electures is offline   Reply With Quote
Old 06-29-2012, 06:56 PM   #6
Electrical Contractor
Use a BFH!
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
The Following 2 Users Say Thank You to jbfan For This Useful Post:
Evstarr (07-07-2012), Techy (06-29-2012)
Old 06-29-2012, 07:27 PM   #7
electures's Avatar
Originally Posted by jbfan
Use a BFH!
Or an even bigger bfh!
Sizing motors
The Following 4 Users Say Thank You to electures For This Useful Post:
ddawg16 (06-30-2012), Evstarr (07-07-2012), jbfan (06-29-2012), Techy (06-29-2012)
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 10:02 AM
Drywall over Drywall.. NoviceHandyman Drywall & Plaster 6 01-10-2011 09:32 PM
drywall over old plaster... lcann25 Remodeling 0 09-21-2010 12:53 AM
Repair drywall paper before laying tile? amybeth25 Remodeling 4 08-29-2010 06:49 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
