How To Figure Load On A Circuit - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 05-16-2013, 02:13 AM   #31
Rewards Points: 744
And, in all other applications, Amps = watts/volts
Seattle2k is offline   Reply With Quote
Old 05-16-2013, 06:19 AM   #32
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Originally Posted by Philly Master View Post
Your basic homeowner 1/3 HP sump is about 800 running watts and 1300 starting watts ....
20 amp circuit is 2400 watts
Originally Posted by crescere View Post
Are you saying:
Sump (at start) = 1300
Dish washer = 1100
Garbage disposal = 750
Total 3150 exceeds max of 2400
YES....
Ok, I find the watts on the appliance, but where do I find the max watts for any given circuit?
already answered ......
120 v times the breaker size ... or 120 v x 20 amps= 2400 watts ... max watts on that circuit
120 x 15 amps = 1800 watts
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 05-16-2013, 06:38 AM   #33
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
A dishwasher/disposal are not listed to be on the same circuit as the sump. Likewise, a sump pump will generally require its own circuit. Since the manufacturer's specs/listing becomes part of the code, to put the sump on with these appliances is a code violation.
It is obvious the OP does not care about code compliance, so I suggest giving this poster any advice other than what code states.
Run a new circuit. If you don't want the GFI in the crawlspace, install a GFI breaker, or a deadfront GFI outside the crawlspace to feed the sump receptacle.
The Following 5 Users Say Thank You to k_buz For This Useful Post:
Jim Port (05-16-2013), Kyle_in_rure (05-16-2013), MTN REMODEL LLC (05-16-2013), Philly Master (05-16-2013), rjniles (05-16-2013)
Old 05-16-2013, 08:30 AM   #34
Rewards Points: 309
Originally Posted by k_buz View Post
A dishwasher/disposal are not listed to be on the same circuit as the disposal. Likewise, a disposal will generally require its own circuit. Since the manufacturer's specs/listing becomes part of the code, to put the sump on with these appliances is a code violation.
...And an alarm if it is a critical sump pump.
al_smelter is online now   Reply With Quote
Old 05-16-2013, 09:14 AM   #35
Rewards Points: 150
I am not at the house now, and when I am I do not have a fancy internet phone to post here. Again, I assume I just add up the amps to see if they exceed 20? Or is there some other maximum like 80%?
Yes, stay under 80%. 16A.
http://www.sears.com/ue/lawn/Sears+Generator-WattageWorksheet.pdf
http://www.housenspect.com/pdfs/07-6...ence-Guide.pdf
Appliance: Running/Starting
Sump: 1050/2200
Dishwasher: 1500/1500
Disposal: 850/2000
The thing is though that the garbage disposal is certainly intermittent. No one leaves theirs on for more than a few minutes.
True, but one might typically start the dishwasher, then clean the sink, then run the disposal. If the Sump kicks on then too, all 3 are quite probably going to run at once. Not worth the risk.
Running wattage total is 3400. /120 = 28A. Way over.
Maybe your appliances are smaller. Pick what you have from the lists above.
SquishyBall is offline   Reply With Quote
Garage light circuit issue Uncle Ben Electrical 15 03-02-2012 02:00 PM
Dispute: Oven malfunction after h/w guys used the circuit rational Appliances 18 05-17-2011 11:37 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Can this circuit handle the load seahawk2000 Electrical 8 01-05-2009 09:12 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
