How To Fasten Service Panel To Stucco Wall? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-02-2009, 12:00 PM   #1
How to fasten service panel to stucco wall?
Hello,
I may be asking a trivially easy question, but what is the best way to fasten a meter/service panel to existing stucco walls. I will be doing a surface mount installation with an overhead service drop.
Thank you for your insight!
RxScram is offline   Reply With Quote
Old 09-02-2009, 12:07 PM   #2
300zx's Avatar
Post
Is there plywood behind the stucco ? If so just use screws or try to find one of the studs.
300zx is offline   Reply With Quote
Old 09-02-2009, 12:08 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
If none of these ideas work, toggle bolts.
Old 09-02-2009, 01:16 PM   #4
Rewards Points: 78
The question is "whats behind the stucco"? It's block in our area, but could be anything in your area. Answer the question and you will get the answer. You have to support the riser too. Have you thought about that?
Old 09-02-2009, 01:27 PM   #5
I'll need to check to see what's behind the stucco. From some other work I've done, I'm pretty sure it's just over some lathe (chicken wire type). I haven't seen any plywood or other solid backing, but I've always been coming from the interior side of the wall.
I have thought about supporting the riser, and figured that whatever means I use to secure the panel would have to be the same means that I secure the brackets.
Old 09-03-2009, 01:14 PM   #6
Lots of stucco homes here and lots of surface mounted overhead panels.
If it's stucco over block, use 3/8" x 2.5" sleeve anchors. For years we used simple 1/4" plastic anchors with #10 x 2" an head sheet metal screws. The bigger sleeve anchors are a much better installation.
If it's stucco over framing you need to located at least one stud and drill holes in the panel to accept a couple of 3/8" lag bolts. The lenght depends on the depth of the stucco backing. There is sometimes 1.5 inches of foam behind it.
The riser support is perhaps more important than the panel itself. If it goea through the eave, a mast brace between the rafter tails will do the trick. If it is on a gable end or a flat roof house, use a piece of unistrut anchored securely. Here we have to through bolt the riser support through the framing or parapet wall.
220/221 is offline   Reply With Quote
Old 09-03-2009, 01:30 PM   #7
Thank you! It's stucco over framing, so it looks like I'll be doing some drilling.
The poco installation guidelines state that I should use "2' * 4" Blocking between rafters. Solidly Installed." I'm assuming that the 2' part is a typo, and that it should be 2" * 4". The mast will be coming up through the eaves, with the load center line 20" above the roof, and a total mast height of 36". (I need to double check the load center line, but I'm pretty sure that's what the poco meter spot specified.) The requirements didn't say anything about guy wires being needed, so I'm assuming they are not. (I'm using 2" IMC conduit)
Old 09-03-2009, 02:33 PM   #8
Rewards Points: 78
Let the studs determine where the panel will be mounted. The studs should be 16" on center. If you can find exactly where the studs are, you can screw right into them. You do not need a horizontal block as they say. But you want to get both sides of the panel screwed tight to the wall.
For your mast you can install a couple short sections of channel (Unistrut) horizontally so you can catch the studs. Then you just get the conduit straps that go with the channel and you are all set. I wish I had a picture for you. Maybe someone else will.
There are so many ways to do this, it would be impossible to explain all of them. Have you considered calling an electrician. I personally do not consider this a DIY project. You could be without power for days if you do not know what you are doing.
Old 09-03-2009, 03:15 PM   #9
They may have meant 22.5" (distance between the rafters) by 4"
Here we are required to use a mast brace that installs in front of the riser on a piece of 3/4" IMC, holding it tight to the structure.
Disregard the fact that in this pic the brace covers the jbox rendering it inaccessible. It's the only pic I could find.
On service upgrades, I let the existing cable determine the location. The panel will hit at least one stud no matter where it's placed. A couple of stout anchors along with a couple of mediocre ones will work fine.
I think the block was for the riser, under the eave.
Sometimes the riser is too tight to the wall to use unistrut.
Here's a gable end installation (no rafter tails) with thru bolted unistrut support.
Old 10-28-2011, 01:37 PM   #10
Who manufactures this brace...
220/221, I realize this is an old post, but who manufacturers this mast brace? I can't find it anywhere locally... or online for that matter.
It is EXACTLY what I need!
risingvoice is offline   Reply With Quote
Hot and Neutral at Service Panel Bocolo Electrical 10 03-09-2009 10:23 PM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 12:33 PM
Stucco wall in yard Colorado Steve Landscaping & Lawn Care 5 05-07-2008 08:24 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Basement receptacle under service panel mekanic Electrical 2 05-12-2006 06:41 AM
