How Far Should Electrical Boxes Be From Plumbing? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-24-2011, 04:52 PM   #1
How far should electrical boxes be from plumbing?
I am remodeling my shower. When I removed the tile, backerboard and greenboard, I discovered the electrical box is touching the plumbing. I am fairly certain that this is NOT a good idea.
Mindy
Richardson TX
zmindyk is offline   Reply With Quote
Old 10-24-2011, 05:41 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Although it is not a huge issue, they should not really be touching. Almost touching is fine.
The Following User Says Thank You to Speedy Petey For This Useful Post:
zmindyk (10-24-2011)
Old 10-24-2011, 07:48 PM   #3
liscenced electrician
Rewards Points: 538
no reason they couldn't be touching. IF its a metal box, it should be grounded. If its a metal water pipe, it should be grounded. If either are plastic, even less reason to worry about it
jimmy21 is offline   Reply With Quote
Old 10-24-2011, 08:24 PM   #4
Electrician
Rewards Points: 792
As long as the water pipe doesn't go through your box you are good
darren is offline   Reply With Quote
The Following 2 Users Say Thank You to darren For This Useful Post:
mpoulton (10-25-2011), zmindyk (10-24-2011)
Old 10-26-2011, 01:00 AM   #5
Limited Experience
Having two different metals touching will usually lead to galvanic reactions which will weaken one or both metals.
See en.wikipedia.org/wiki/Galvanic_corrosion
And since there will always be some stray voltage you'll get a slow but steady reaction over time.
Put something between them.
raleighthings is offline   Reply With Quote
Old 10-26-2011, 01:12 AM   #6
Rewards Points: 6,652
If it was me, and how I did it, let me put it this way. From four feet from the corner at the right side of the vanity, is the outlet. That places the outlet aprox. four feet from the shower head, which is left of the vanity.
Old 10-26-2011, 01:12 AM   #7
What in the world are you talking about?
Old 10-26-2011, 01:14 AM   #8
Limited Experience
Any time you have two DIFFERENT metals touching you will likely get a galvanic reaction. Basically one or both will corrode. It's chemistry.
If you have a steel electrical box touching a copper pipe you'll get corrosion over time. Maybe a long time but it will happen.
The Following 2 Users Say Thank You to raleighthings For This Useful Post:
jimmy21 (10-26-2011), Speedy Petey (10-26-2011)
Old 10-26-2011, 01:41 AM   #9
harry_ho's Avatar
Older electric water heaters are bad about this when plumbed into copper pipes. Today's heaters have dielectric nipples installed from the factory to prevent this reaction.
harry_ho is offline   Reply With Quote
Old 10-27-2011, 08:21 PM   #10
Electrical Contractor
He's right. Just wrap some duct tape around the copper line where it makes contact with the galvanized box, problem solved.
Sine is offline   Reply With Quote
Old 10-28-2011, 08:45 AM   #11
Say what? And where did you come up with that, Bubba's book on home repair?
Old 10-28-2011, 08:46 AM   #12
I know what galvanic reaction is. If the electric box is touching a copper water line, you know then and there, that Bubba was doing the work.
Old 10-28-2011, 04:34 PM   #13
No, The jumbo duct tape book You just have to make sure it's UL listed.
Old 10-28-2011, 05:30 PM   #14
Electrician
SD515's Avatar
Rewards Points: 504
My 2 best friends...duct seal and duct tape
Kyle
Old 10-28-2011, 08:53 PM   #15
Rewards Points: 538
And tie wire?
Installing ceiling fans, having trouble removing old electrical boxes donaldball Electrical 8 06-13-2011 11:51 AM
fitting electrical wires to back boxes 1st fix Minimin Off Topic 2 05-03-2010 04:38 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
Installing electrical boxes MikeyP Electrical 4 07-26-2009 09:32 AM
Air Sealing of Electrical Boxes on exterior walls PerpetuallyRepairing Electrical 6 07-14-2009 08:38 AM
