How Far From House For Ground Transformer? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-28-2008, 09:52 PM   #1
How far from house for ground transformer?
Am getting ready to start building a new house out in the country.
The electric co-op will trench in high voltage line to the rear side of the house, where it will be cut to 240v in a ground mount transformer. After the walls are up, they will return and trench in the 240 primary to a meter on the house and we will hook up the rest.
Is there code on proximity of the high-voltage ground mount transformer to the house? Any suggestions for aesthetics or safety?
Thanks,
Greg
GregWCIL is offline   Reply With Quote
Old 06-29-2008, 01:44 AM   #2
Idiot Emeritus
Rewards Points: 1,492
Generally, the power company is completely in charge of everything on their side of the meter. The National Electrical Code specifically exempts public utilities from any and all code requirements. The local building department usually doesn't inspect power company stuff either. If the Power company approves it, then you're OK.
Rob
micromind is offline   Reply With Quote
Old 06-29-2008, 02:30 AM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
If the placement of the pad mount is of concern it is possible to get them to put it where you would like it (within reason of course.) You may incur some cost if you want it a long way from the house as the secondary lateral may be of a length the utility will require additional payment for special location due to added wire costs.
Old 06-29-2008, 08:30 AM   #4
Thanks for the replies.
The electric co-op is very accommodating. Where they initially flagged to place the transformer was about 20 ft. behind the garage--close enough to minimize voltage drop but far enough to allow mowing around it.
My only other thought would be to put a concrete pad for it directly against the garage but that complicates the construction process and may raise so safety issues--it is 7200 volts primary.
Greg
Old 06-29-2008, 09:59 AM   #5
joed's Avatar
Rewards Points: 11,962
There should be no safety issues. All the connections should completely enclosed and inaccessible.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 10:04 AM
200 Amp service really needed for a 830 sq ft house? overkill? alexz Electrical 7 11-16-2009 06:54 PM
Hello. I moved my house... shtoink Introductions 10 06-25-2008 02:40 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 06:42 PM
