How To Extend Flexible Steel Conduit Run - Electrical - DIY Chatroom Home Improvement Forum
Old 08-31-2010, 04:18 AM   #1
Rewards Points: 337
how to extend flexible steel conduit run
I am having me kitchen remodled and I an moving my penisula 24" down the run that it used to be. I just got to thinking, my existing outlet for the penisula will be too short to reach it's new location. How can the box conduit be extended? I believe it come up from the slab through the bottom plate it's not getting moved. Can I have the outlet and box removed and have it go into a Juntion box in the dead area behind the cabinets and then it can be extended from there?
thanks!
titan7 is offline   Reply With Quote
Old 08-31-2010, 05:46 AM   #2
Rewards Points: 1,192
The junction box must be accessable.
bobelectric is offline   Reply With Quote
Old 08-31-2010, 03:07 PM   #3
Rewards Points: 337
If I attach a J-Box to the cabinet under the sink or the cabinet with the pull out trash cans, is that considered "accessable"? You would need to open the drawer and remove the trash cans, then remove the cover plate.
Old 08-31-2010, 06:24 PM   #4
Licensed electrician
Rewards Points: 1,276
That would meet the definition of accessible.
Old 08-31-2010, 07:47 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
by using a coupling and a piece of flex as long as you need.
that is an internal coupling. They also make an external but I couldn't find a picture quickly.
Old 08-31-2010, 11:29 PM   #6
Rewards Points: 337
I don't think the coupler will work. Actually I don't think I have many options other than adding a J-box. Correct me if I am wrong, but since this conduit runs into the bottom plate would that mean it goes into the slab?? Why would they do this since there is a 20 amp outlet on the same wall 4 feet away. The conduit definiatly goes to the bottom plate. I was thinking I could just tie into the other one on the wall and run conduit from there to the penisula outlet but I can't bury the original run.
Suggestions?
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 07:49 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Armored cable run outside in liquid flexible conduit m_driver Electrical 8 07-06-2008 03:15 PM
Basement Electrical- Flexible Conduit? H Thomas Electrical 2 04-20-2006 09:42 PM
pulling wire through old flexible conduit cbray Electrical 1 05-20-2005 04:55 PM
