How Does This Rough In Look? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-12-2011, 09:18 AM   #1
Rewards Points: 150
How does this rough in look?
Can I get someone to take a look at this and let me know if it looks kosher?
This is a 4' light for an attic.
Attic area
14-2 wire leading to fixture:
Into the fixture:
Connections:
sheslostcontrol is offline   Reply With Quote
Old 02-12-2011, 09:39 AM   #2
Scared Electrician
Saturday Cowboy's Avatar
looks legit from photos
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 02-12-2011, 10:19 AM   #3
Looks good. Nice work.
I might have put in an outlet instead of hard wiring the light. that way when the light needs replaced you don't need to mess with any wiring, just plug in the new light and you're done.
bhennon is offline   Reply With Quote
Old 02-12-2011, 10:20 AM   #4
Experienced
Jackofall1's Avatar
Is you J-box fill correct?
How many conductors of what gauge?
Box size in in3?
Mark
Old 02-12-2011, 10:24 AM   #5
Rewards Points: 330
if that is a wire 12-2 going past the crawal access,it needs to be 6' away or guarded.that goes for water,gas also.also use wire nuts on your ground in lite just easier.code article:320.23(A) is where you can find requirement.
oleguy74 is offline   Reply With Quote
Old 02-12-2011, 11:29 AM   #6
Rewards Points: 150
As I'm looking at this light in the attic.. will inspectors let this non-covered T5 pass? I've heard that covered lights are required in closet areas.
Old 02-12-2011, 11:32 AM   #7
Rewards Points: 150
You see a 14-2 going past the attic space door. The inspector said on the phone that I need to crimp the grounds for rough in. He hasn't been to inspect yet, hence this post. Just want to make sure my work looks good.
Old 02-12-2011, 11:51 AM   #8
Rewards Points: 330
14-2 or 12-2 dosent matter needs to be 6' or guarded.as for grounds,he brobly wants them crimped in outlets.but thats ok.looks good other wise.
Old 02-12-2011, 12:27 PM   #9
Master Electrician
Rewards Points: 3,864
Delete
brric is offline   Reply With Quote
Old 02-12-2011, 12:28 PM   #10
Rewards Points: 150
Good deal.. the 14-2 will be coming out anyway, it's part of the old wiring. I'll check other sides of the opening too.
Old 02-12-2011, 12:28 PM   #11
Master Electrician
Attic space does not equate to closet.
Old 02-12-2011, 12:28 PM   #12
Rewards Points: 150
Originally Posted by brric View Post
Delete
Why would I delete this?
Old 02-12-2011, 12:30 PM   #13
Master Electrician
Sorry, it was my reply that was deleted.
Old 02-12-2011, 12:47 PM   #14
Rewards Points: 150
Ok no problem -- got your message about the closet not being same as attic. thankx
Old 02-12-2011, 01:36 PM   #15
Not much in the way of electrical work is shown but what is shown looks ok. The framing is another story. Purlins should be the same size as the rafters they support. Purlin braces should land on a bearing wall or a beam, not ceiling joists. The same holds true for ridge supports. Their appears to not be a rafter to ceiling joist connection and therefor, no rafter tie. The ceiling joist appear to have insufficient bearing on the wall top plate.
Tigerloose is offline   Reply With Quote
1991 Pontiac 6000 v6 3.1l running rough Patriot_RAM Automotive Repairs 17 10-09-2010 04:00 AM
Basement bathroom rough in plumbing ferris13 Plumbing 5 09-28-2009 10:06 AM
Basement Toilet Rough In - Help atm Plumbing 3 06-06-2009 11:04 AM
Replace a 10" rough in toilet with a 12" rough in Opie46 Plumbing 3 05-16-2009 11:27 AM
shower rough in frusteration! Lmiller Plumbing 5 03-13-2008 12:24 PM
