How Does One Extend 12/2 Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 06-09-2010, 12:59 PM   #1
K.M.G's Avatar
Rewards Points: 105
How does one extend 12/2 wire
Hi
Well it seems I didn't buy enough 12/2 for my dishwasher hook up
It's short by 3 feet to pull the Dishwasher out for me to hook the wires up
How do you extend wire in a safe and correct way,a junction box comes to mind but I don't know what is what.
The Dishwasher has been sitting in the kitchen for 3 months now
please do help me
K.M.G is offline   Reply With Quote
Old 06-09-2010, 01:06 PM   #2
joed's Avatar
Rewards Points: 11,548
A junction box it required . It must remain accessible. Behind a dishwasher is accessible.
Old 06-09-2010, 01:17 PM   #3
K.M.G's Avatar
Rewards Points: 105
What exactly do I look for,do they make ones just for this problem
How are they hooked up
My Bathroom Project done
http://www.diychatroom.com/f49/bathroom-done-70572/
Thankyou everybody for your help!!!
Old 06-09-2010, 01:35 PM   #4
Rewards Points: 1,418
A junction box could be a blue plastic box used to hold a switch or receptacle in the wall. A suitable junction box could also be a metal box of about the same size (something like 2-1/2 x 2-1/2 x 4 inches) with a slightly rounded back. Other shapes and sizes exist too.
The metal boxes have round cutouts that you can bend and break off to provide openings for the cables. A cable clamp is needed to line the opening and cover up the sharp edges. Don't break off more tabs than you need otherwise you must buy snap in round caps to cover any unused openings; the caps cost as much as the box.
If you use a plastic box, choose one with plastic tongues that hold the cable in place as it enters the box.
Old 06-09-2010, 01:37 PM   #5
Just call me Andrew
Rewards Points: 1,020
You screw the J-box to the wall. Splice some more wire to the old (black to black, white to white, ground to ground) with wire-nuts. This splice (all the wirenuts) must be in the box,
If the box is metal (as opposed to plastic), a ground wire must be attached to the box itself and also to the two ground wires in the box (so that wirenut would have 3 in it).
You also need clamps. Metal boxes usually don't come with clamps. Some plastic boxes do.
Easiest way is probably a small plastic box (with built-in clamps) and a blank cover plate.
Andrew
secutanudu is offline   Reply With Quote
Old 06-09-2010, 02:37 PM   #6
K.M.G's Avatar
Rewards Points: 105
I hate to ask
but would you have a diagram
I can see it but I don't understand how to wires are hooked up 100%
These juncion boxes have two ground screws right
each ground from the wire go to those ground screws wraped around tight
then white+white and black+black=done
AllanJ talks about 3 ground wires?? but I only have two grounds being it's 12/2 wire.
Old 06-09-2010, 02:39 PM   #7
If you check Rexel Elec. Supply I think somebody makes an approved splice for solid wire.
Old 06-09-2010, 05:12 PM   #8
Sparkaholic
Rewards Points: 150
Send a message via Yahoo to sparks1up
If it is long enough to make it into the under sink cabinet you would be better off to run it there and install a a single 20-amp receptacle outlet in a box. Then install a cord and plug on you dishwasher and run the cord through the cabinet and plug it in. This way when you have to remove it you can disconnect power by unplugging it before you pull it out.
You can buy the cord at any Home Depot, Lowes or Big Box store.
There is no approved method of splicing a romex cable for this application other than installing a box to make the splice in. While there are different ways you can make the splice they all have to be contained in a box.
Answers based on the mood I am in when you ask!
sparks1up is offline   Reply With Quote
What type wire to use from transfer switch to outdoor outlet brjl Electrical 32 11-20-2013 09:36 AM
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 07:41 PM
Decommissioning old armored wire circuit toddmanqa Electrical 6 12-04-2009 09:55 AM
2 Wire Thermostat question vtec69 Electrical 19 10-19-2009 06:14 PM
New Dryer is 3 wire, receptacle is 4 Wire. thelimit Electrical 22 01-15-2009 10:59 AM
