Originally Posted by zappa
Can you tell if the relays are actuating? I added a line to my last post.
Ahh, thanks, missed the edit. Can't tell if they are actuating for sure. They're wrapped in some type of black plastic-type material. You can see a picture of it at
SM120X Relay Module.pdf. It's the one on the right.
Can the relays be unplugged? (socket type). Another good test.
Sort of... I'm using the ideal in-sure wire connectors, so I have to kill the circuit while making changes. Speakerphone + wife makes it easier, though.
Originally Posted by kbsparky
Sounds like you are picking up some induction (Phantom) voltage there.
It may not be an issue with everything connected ....
Ahh, you might be dead on. Looked into induction/phantom voltage, and found discussions like
Phantom voltage reading on switch loops.
Never considered that you'd have induction from the source hot to the return hot on a switch loop, makes perfect sense though. Looks like the amount detected varies on each multimeter model based on its resistance, but that thread discusses 15v, which is dead on to the 17-18v I'm detecting.
I'll measure the current later tonight or tomorrow to confirm that it's phantom voltage with extremely minimal current.
Perhaps the 17-18v was a red herring...
