How Do You Connect Tiny 12 Volt Wires Together? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-27-2012, 02:47 PM   #1
kmc
How do you connect tiny 12 volt wires together?
I got some new sockets for my can lights and need to cut the existing wires and couple them to the 0.5 mm^2 socket wires. That's 24.5 gauge if I understand correctly. So obviously the small nuts at HD are too big (min 22 gauge). Any suggestions?
kmc is offline   Reply With Quote
Old 05-27-2012, 02:56 PM   #2
Sparky
Rewards Points: 510
Small Blue or Small Grey wirenuts
Techy is offline   Reply With Quote
Old 05-27-2012, 05:31 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Even orange wire nuts should work. OR you can use ceramic terminal blocks, I prefer these actually.... wire nuts tend to break down after awhile from the intense heat....
http://www.tempco.com/Catalog/Sectio...m%20Blocks.pdf
Old 05-27-2012, 05:54 PM   #4
Household Handyman
Rewards Points: 1,408
Danged, I tried to copy and post a photo, but: I like to use a "WAGO" brand wire terminal for small wiring. Google "WAGO" and you can find them. You just raise up the little lever, put the unstripped wire into the hole, release the lever, and you have a great connection. I buy them from Fastenal in my area (can I say that?).
Old 05-27-2012, 05:56 PM   #5
E2 Electrician
I doubt those will last in an MR16 compartment... Remember ceramic won't become brittle from the high temps....
Old 05-27-2012, 09:01 PM   #6
kmc
Thanks I actually did find them at home depot. I got the yellow telephone wire nuts. It's led so I doubt heat will be an issue.
Old 05-27-2012, 09:36 PM   #7
You can solder and insulate with heat shrink tubing also!
Old 05-27-2012, 11:14 PM   #8
Master Electrician
why wouldn't you just run the new sockets wires through the flex into the connection box like the current ones are and make the joints there. Or if it's a top mount connection box go that route, basically follow the path that the existing wires are going and replace at the first joint. The tails on the new sockets should be plenty long enough for that.
Those little plastic splices are going to melt next to an mr16, go with the ceramic if you have to make the joint.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 05-27-2012, 11:39 PM   #9
kmc
They're 6 watts each. These sockets are not even close to long enough to stick through the hole in the can where the wires come through. And I really don't feel like going into the attic to splice 16 pairs of wires.
how to connect an US220 volt gustavo Appliances 1 10-08-2011 06:15 PM
Can I connect 3 relays to one, 12 volt ac adapter? tibberous Electrical 25 07-27-2011 10:31 PM
Neutral Wires Hot Problem rayray221 Electrical 7 09-20-2010 12:20 PM
Ceiling Fan installation, 3 sets of wires in ceiling southnam Electrical 3 09-13-2010 04:00 PM
240 volt circuit and 120 volt circuit to shed fortop Electrical 27 06-26-2010 12:37 PM
