How Do You Annotate/mark Wires In The Same Circuit? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-28-2012, 05:05 PM   #1
Rewards Points: 1,628
How do you annotate/mark wires in the same circuit?
Is there any convention employed by the pros as far as identifying, tagging, annotation wires in the same circuit appearing twice in the same conduit?
For example I have a hot wire from circuit 7 coming into the box. The wire than runs to another box to a switch and back through the same rigid conduit. So how I have three wires in this box from circuit 7. Is there any sort of convention to mark it so I know which wire is GOING TO the switch and which wire is COMING from the switch?
miamicuse is offline   Reply With Quote
Old 05-28-2012, 05:16 PM   #2
Licensed electrician
Rewards Points: 1,608
Some would use a different color for the switched hot. A tape wrap could work also.
Old 05-28-2012, 09:41 PM   #3
" Euro " electrician
frenchelectrican's Avatar
You can use the coloured tape simauir what the Chicago codes been using for a quite a while.
White-Neutral
Grey-Dedicated neutral for GFCI
red-black -blue--Power
Brown--travelers for three way
purple--GFCI protected power
yellow-orange---switch legs
Note : you may want to modifed the listing if you have AFCI circuits so subuite or make a double stripe tape to indentify a AFCI protected verison.
Merci,
Marc
Kitchen circuit re-design - Existing is a mess darlingm Electrical 5 12-31-2011 09:45 PM
Lost Neutral on K&T Circuit RST Electrical 4 11-29-2011 11:25 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Tracing wires from Circuit breaker to outlet/switch Evil Scotsman Electrical 8 11-16-2010 05:38 AM
adding 2nd floor circuit by running wires outside in PVC - advice? reags Electrical 16 08-06-2010 10:32 AM
