How Do We Fish Wire Thru A Corner - Electrical - DIY Chatroom Home Improvement Forum
Old 02-16-2012, 03:34 PM   #1
How do we fish wire thru a corner
how do we fish a wire thru a corner.
Hardway is offline   Reply With Quote
Old 02-16-2012, 03:40 PM   #2
Learning Things Every Day
Jay 78's Avatar
Wrap wire around a straightened out coat hanger.
Under Construction
Jay 78 is offline   Reply With Quote
Old 02-16-2012, 03:46 PM   #3
Rewards Points: 12,802
I drill two over sized holes at an angle and strip the insulation off the wire about 6", twist them together and feed it through. May need to add nailing plates.
Old 02-16-2012, 03:54 PM   #4
i am tying to figure out how to post drawing from paint, simple drawing. it won't up load to big, so it say.
Old 02-16-2012, 03:58 PM   #5
Hole in center of ceiling, pulling wire to wall then down the wall to hole in the wall for say a switch. Donít want to make a big hole. So how do we get thru the top plate?
Writerís information is for discussion purpose only and should be confirmed by an independent source.
Old 02-16-2012, 05:35 PM   #6
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
You need a hole just large enough in the wall to drill a hole through the top plate I think it's 1-1/4 from the edge. I use a flexible extension for my spade bits and it works great. Then I work my fish tape through the wall into the ceiling using the hole you used to drill through you will need to use a coat hanger or fingers to line the fish tape up with your hole. Then you may also need another hole in the ceiling near the wall to hook onto your fish tape to get the fish tape going the direction you want.
If the wall in insulated you can use a thin piece of wood or something to push it out of your way so you can drill. A helper comes in handy.
rrolleston is offline   Reply With Quote
Old 02-16-2012, 11:22 PM   #7
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Is the wall open or dry walled?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-17-2012, 12:40 AM   #8
Wet plaster and lats.
Old 02-17-2012, 01:03 AM   #9
rrolleston's Avatar
You can make small holes and plaster over them.
Old 02-17-2012, 08:02 AM   #10
Rewards Points: 6,652
When we gutted our bath, I took a crowbar, pried the corner far enough that my son could get his fingers back there to push through the other side. It took some trust. Even with a coat hanger, it is hard to do.
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 07:41 PM
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 08:07 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
