#1 |
How do I wire these switches?
I have one hot wire coming to a switch outlet. I also have two wires that have connected 4 recess lights each, and also I have a wire that is going on to power up a outlet few feet below the switch. I would like to install two switches at this outlet to control the 8 recess lights (for each)
So I have Black Hot - BH White Hot -WH Swtich 1 Black - BS1 Switch 1 White - WS1 Switch 2 Black - BS2 Switch 2 White - WS1 Black Wire that connects the recess lights and should be controlled by Switch 1 - BW1 White Wire that connects the recess lights and should be controlled by Switch 1 - WW1 Black Wire that connects the recess lights and should be controlled by Switch 2 - BW2 Black Wire that connects the recess lights and should be controlled by Switch 2 - WW2 Power outlet Black - BP Power outlet White - WP Assuming that all ground has been connected together. I wired all black to black and all white to white and my braker faulted. What am I doing wrong? IN my wiring I used a jumper wire to limit the wire connection to 4 wires per cap. Thanks, |
#2 |
Licensed Pro
There should be no white wires connected to a switch.
WH, WP, WW1, WW2 are connected together. BH, BP, BS1, BS2 are connected together. BW1 goes to remaining screw of sw1 BW2 goes to remaining screw of sw2.
"Life is hard. Life is harder when you're stupid." John Wayne |
| Display Modes | |
| Real Basic Electrical question re: neutral wire | hellothere123 | Electrical | 22 | 07-21-2009 07:07 PM |
| Fishing Wire | MikeyP | Electrical | 17 | 12-01-2008 11:05 PM |
| Neutral Wire? | 4x15mph | Electrical | 8 | 11-24-2008 02:00 PM |
| Separating Fan and Light Switches | GeauxCajuns82 | Electrical | 11 | 08-26-2008 01:03 AM |
| Stranded wire on screw connections | BigJimmy | Electrical | 7 | 01-19-2008 03:42 PM |
