How Do I Wire A Fan & Light?? Diagram.... - Electrical - DIY Chatroom Home Improvement Forum
Old 01-06-2009, 12:01 AM   #1
Question
Hello all, first post but sure to not be my last....
I am building a new bathroom in my dowstairs and am installing two lights (these will run off ONE switch) and a bathroom Fan which will run off the other switch. The switches are in a dual box on the wall with the power source entering in to the switchbox in the wall.
Is the diagram I drew below correct? If not could you please correct my mistakes?
Thanks in advance!!
C
4wheeling is offline   Reply With Quote
Old 01-06-2009, 07:43 AM   #2
I don't like the part where there is one hot running seperate from the circuit, are you running one cable to the light and one cable to the fan? This is how I would do it.
Is it a fan/light combo? If so, the last picture shows how I would do it.
rgsgww is offline   Reply With Quote
Old 01-06-2009, 10:44 AM   #3
No it is not a fan/light combo.
It is 2 pot lights running off 1 switch and then a seperate bathroom fan running off the other switch.
Which of your diagrams works for that? I am not sure I understand what the black circles you drew mean.
C
Old 01-06-2009, 10:48 AM   #4
C
The black circles represent the cable. It would be the first drawing.
What size breaker is this circuit on?
15 and 20 amp diagrams:
Old 01-06-2009, 11:26 AM   #5
Wow!
It would have taken me three hours to figure out how to draw that.
15 AND 20 amp!
You even did the yellow cable !
220/221 is offline   Reply With Quote
Old 01-06-2009, 11:26 AM   #6
awesome! Thank you very much!!!
Old 01-06-2009, 11:49 AM   #7
Rewards Points: 506
Send a message via AIM to theatretch85
Something you might want to consider is to run either 12/3 or 14/3 (depending on the size of the circuit) to the fan unit in the event you or someone else wants to change to a fan/light combo unit later. You just wouldn't use the red wire and cap it off on both ends; sounds like you still have to run the wire anyway, might as well make it future-ready.
theatretch85 is offline   Reply With Quote
Old 01-06-2009, 11:50 AM   #8
Rewards Points: 204
How are you guys making these drawings? I sure would like to know how. Thanks John
Old 01-06-2009, 12:08 PM   #9
I made the first drawing in Photoshop.
Old 01-06-2009, 12:15 PM   #10
I modified his using paint (yes, I know)
I usually will use The Gimp.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Replacement Light Fixture - Speed Wire Clip? nick4597 Electrical 4 01-03-2009 12:49 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 06:02 AM
