How Do I Wire A Electrical Timer? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-20-2012, 07:21 PM   #1
how do I wire a electrical timer?
I have an electrical timer with a red, a white, and a black wire, but the box only has a white and a black wire. What does the red wire connect to?
CBR_up_on_1 is offline   Reply With Quote
Old 01-20-2012, 07:31 PM   #2
MarginallyQualified
Rewards Points: 2,464
what do the instructions say?
is there a make and model number on it?
Old 01-20-2012, 07:35 PM   #3
Rewards Points: 506
I would venture to guess that the red wire connects to the device being timed. Might not work in a switch loop scenario.
jlmran is offline   Reply With Quote
Old 01-20-2012, 07:44 PM   #4
The manufacturer is Woods,it's a in wall mechanical timer model # 59017. The instructions say W to W, B to B, and R to B (load)
Old 01-20-2012, 07:47 PM   #5
Rewards Points: 506
What are you wishing to time?
Old 01-20-2012, 07:47 PM   #6
Licensed electrician
Rewards Points: 1,892
The white is providing power to the switch and the black is the switch controlled hot.
You do not have a neutral and the timer cannot be used with your setup.
Old 01-20-2012, 07:53 PM   #7
Rewards Points: 506
The OP has not said that he/she is replacing a switch...you assumed that. For all we know, the box mentioned could contain a hot and grounded conductor.
Old 01-20-2012, 07:56 PM   #8
Thank you Jim Port. I guess I'll return it and look for a different type. Any suggestions? I am timing a light.
Old 01-20-2012, 07:58 PM   #9
Yes I am replacing a switch.
Old 01-20-2012, 07:58 PM   #10
This is the OPs post
Sounds like there is no option, either it is a switch loop as I posted or it is a hot and a neutral with no load wire. It would be unusual to replace a receptacle with a timer.
Old 01-20-2012, 07:59 PM   #11
Jlmran: yes I am replacing a switch
Old 01-20-2012, 08:04 PM   #12
Rewards Points: 506
I just did not want to assume anything, and I only asked those questions to learn all the details first.
Who posted about a switch loop first?
Old 01-20-2012, 09:51 PM   #13
MarginallyQualified
look for one of these:
Schedule 40 PVC in Chicago? franwalker Electrical 56 12-20-2011 10:04 PM
Wiring an electrical timer 1Les Electrical 3 12-22-2010 03:00 PM
Four wire electrical + ceiling fan ja0019 Electrical 14 05-09-2010 10:31 AM
Cap electrical wire? oscarMadison Electrical 5 03-01-2009 09:26 PM
Standard gauge for household electrical wire tripower Electrical 2 09-21-2008 11:42 PM
