How Do I Wire 2 110's To Make 1 220? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-30-2011, 05:04 PM   #1
How do i wire 2 110's to make 1 220?
I have an air conditioner that has I believe 6-15 plug. I will need to buy a recep for the plug and a box but what I want to do is use 2 different 110 circuits in my house to make the 220 for the air conditioner to plug in. How do i wire this up? It will just be a temporary setup and only used when needed. in the future I will have a dedicated put in but would like to have it running tomorrow since it will be 105 degrees here. any help will be appreciated. They do sell a corded setup like this but at $160 and shipping time I don't want to bother.
obsidian231 is offline   Reply With Quote
Old 06-30-2011, 05:31 PM   #2
Rewards Points: 330
what size breaker you need?it needs to be a 2-pole.a 6-15 is 15 amp.you can use 14-2/wground.black wire to one side of breaker,white to other side of breaker.ground to ground buss.wire the recp black to one side white to other term.ground to ground term.
oleguy74 is offline   Reply With Quote
Old 06-30-2011, 05:49 PM   #3
plug on ac is 6-15p. is rated at 208-220 at 6 amps single phase is what ac says.
Old 06-30-2011, 05:57 PM   #4
Master Electrician
Rewards Points: 3,808
Is the current receptacle location a dedicated individual circuit or are there other receptacles on the same circuit.
brric is online now   Reply With Quote
Old 06-30-2011, 06:07 PM   #5
Licensed electrician
Rewards Points: 1,456
I think the OP is trying to use the hots from two different circuits to create a 240 volt receptacle or circuit.
Old 06-30-2011, 06:16 PM   #6
This is what i want to do. hard to explain since i don't know technical terms.
http://www.quick220.com/220_pictures.htm
Old 06-30-2011, 06:49 PM   #7
Rewards Points: 1,492
If you want a temporary setup, run a Romex cable from the panel (black and white connected to a double wide double breaker) on the surface stapled to rafters and up the stairs stapled to baseboards and up and around doorways to get to where the air conditioner is. Put a surface mount box with the 240 volt receptacle near the air conditioner.
Old 06-30-2011, 07:06 PM   #8
I=E/R
a7ecorsair's Avatar
I'm sure this "converter" is UL listed
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
gregzoll (06-30-2011)
Old 06-30-2011, 07:40 PM   #9
Thanks allen and everybody else that replied. have to run in morning to get wire. didn't want to but figured this was the way to go. at least now single breaker will pop if it needs to. thanks.
Old 06-30-2011, 08:38 PM   #10
Missouri Bound's Avatar
Oddly enough it IS UL listed.....go figure.
Old 06-30-2011, 08:42 PM   #11
Rewards Points: 6,652
Easy way, would be to have an electrician run two circuits for where the 220vac will be used. Otherwise, using a step up transformer would not be the best, especially in homes, there is more than one outlet fed from the breaker. I can do it with my home, because all outlets run to a junction box under each room for those outlets, so swapping for a 220vac circuit is not that hard for me. For you, it means pulling some romex.
Old 06-30-2011, 08:51 PM   #12
I was just looking at the box. a lot of boxes have no room but this one is huge with lots of room so should be easy to put in. floor joists are all exposed so going to be easy to run the wire plus want outlet next to cold air return in floor board on next level so running wire will be easy. curious what wire gauge I should be using ...12? ac is only 6 amps supposedly.
Old 06-30-2011, 08:53 PM   #13
The trick is to find two circuits on opposite legs of the panel close enough together to use that device. Oh yeah, and don't trip over the cord.
Old 06-30-2011, 08:56 PM   #14
Electrical Contractor
jbfan's Avatar
Rewards Points: 380
14 gage will be fine.
Old 06-30-2011, 09:17 PM   #15
kbsparky's Avatar
Won't work on GFCI and AFCI protected circuits.....
-KB
questions Nichrome wire goldhunter_2 Electrical 4 01-03-2011 07:01 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 07:07 PM
Aluminum Wire Indoors NOTREALSURE Electrical 5 09-24-2010 04:39 PM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
