How Do I Wire This ? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-11-2012, 08:42 PM   #1
Rewards Points: 240
how do i wire this ?
hello gents.
i am wiring my living room. on one side i installed a 14-3 feed wire up to the ceiling fan & light box. the switches need to go on the opposite wall, 1 switch for each.
i would like to run only one cable, 14-3. but i can run 2 14-2's if needed.
what to do, and how ?
thanx
Fix'n it is offline   Reply With Quote
Old 10-11-2012, 09:26 PM   #2
Licensed electrician
Rewards Points: 1,876
What code cycle are you on? Your area may require a neutral at the switch locations.
Old 10-11-2012, 09:31 PM   #3
This may help you, i found it at http://www.wikihow.com/Wire-a-3-Way-Light-Switch,
or i found this for light and fan on separate switches http://www.doityourself.com/forum/el...-switches.html
drwheels is offline   Reply With Quote
Old 10-11-2012, 09:35 PM   #4
Rewards Points: 240
i am tired right now. but i believe its 2001 .
Old 10-11-2012, 09:45 PM   #5
Rewards Points: 240
thanx, wheels. but its not a 3 way switch. its regular switching. but that the power comes in at the device, not the switch.
Old 10-11-2012, 10:04 PM   #6
Rewards Points: 240
well, its bed time now. i sure hope someone can get me the info i need, by 6pm friday. as that is when i have to run the cables. saturday morning is blown cellulose covering the cables day.
Old 10-11-2012, 10:08 PM   #7
Not leaving much time for an inspection are you?
Old 10-12-2012, 05:44 AM   #8
Sparky
Rewards Points: 510
disregard 12-3 on picture, all whites at switches must be remarked black, diagram not code compliant with 2011 NEC
Techy is offline   Reply With Quote
Old 10-12-2012, 06:24 AM   #9
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
I would run 14/2 to the switch, then 14/3 to the fan light.
Isn't Chicago land conduit country anyway?
jbfan is online now   Reply With Quote
Old 10-12-2012, 07:09 AM   #10
Rewards Points: 2,516
power into fan location....12-3 to two single pole switch location
ground wires not shown for ease of drawing
hammerlane is offline   Reply With Quote
Old 10-12-2012, 07:17 AM   #11
Resi EC
Rewards Points: 252
If i read the OP correctly, fix'n is trying to 3-way both the fan and the light and is wondering what wires are needed.
If i'm correct and the power is at the device (fan/light), you will need to drop a 14/2 from the F/L to the other switch location.
Then 2, 14/2 from your existing switches to the new switch location to make the 3-ways work properly.
Gac66610 is offline   Reply With Quote
Old 10-12-2012, 07:22 AM   #12
Resi EC
Rewards Points: 252
What are these inspections you keep talking about ...
Old 10-12-2012, 07:32 AM   #13
In the first post fix-n-it says,
"i am wiring my living room. on one side i installed a 14-3 feed wire up to the ceiling fan & light box. the switches need to go on the opposite wall, 1 switch for each"
I interpreted that as he has a ceiling fan with a light canopy and he wants to install two switches. One for the fan motor and one for the light canopy.
Just another example of a poster not explaining a situation adequately.
Oh well...you can only help so much
Old 10-12-2012, 07:36 AM   #14
Resi EC
Rewards Points: 252
Umm ...opps, you're right, I miss read (sorry)
Old 10-13-2012, 08:47 AM   #15
Rewards Points: 240
the cellulose isn't happening today. i was TOLD it would be in stock friday, it wasn't. oh-well. thats HD for ya.
anyway.
techy's and hammers diagrams are what i am looking for.
thanx fella's
btw. i was tiered when i asked this question. so i described my issue as best i could.
the power to the room is on the east side. the power cable is going up to the F/L. and a cable to the switches on the west wall.
is that better ?
THWN wire; Gray pvc Conduit; and GFCI receptacles Buzzy Electrical 29 09-26-2012 02:41 AM
ceiling fan wicked97 Electrical 4 08-21-2011 08:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
