How Do I Test If A 2 Prong Receptacle Is Wired Correctly Without Taking It Apart? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-13-2013, 10:34 PM   #1
Rewards Points: 89
How do I test if a 2 prong receptacle is wired correctly without taking it apart?
I've tried using a receptacle tester, but figured out this does not work properly without a true ground hooked up to the tester. I know I can test if a 3 prong is wired properly by using a voltmeter with a test lead on the smaller slot (hot wire) and the other test lead to the ground prong. However a 2 prong receptacle does not have a ground. So I was thinking of plugging in a 100 feet extension cord in a working 3 prong receptacle, and use that ground. I would use the voltmeter and put a test lead in the smaller slot of the 2 prong receptacle and put the other test lead in the ground of the extension cord. Would this be a reasonable way to test if a 2 prong receptacle is wired correctly? Thanks in advance.
stanlam is offline   Reply With Quote
Old 08-13-2013, 10:44 PM   #2
Rewards Points: 150
Sometimes the older outlets are in metal boxes and can sometimes be grounded in the box by bx or hopefully not a bootleg ground. You could try going from the hot to the faceplate screw, or take the plate off and go from hot to the box. If that doesn't work, then use the extension cord ground
romex1220 is offline   Reply With Quote
The Following User Says Thank You to romex1220 For This Useful Post:
stanlam (08-14-2013)
Old 08-13-2013, 11:59 PM   #3
Licensed electrician
Rewards Points: 1,618
Your method should work.
Old 08-14-2013, 06:22 AM   #4
PoleCat's Avatar
Rewards Points: 1,646
This is a good job for a tick.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
Old 08-14-2013, 07:18 AM   #5
biggles's Avatar
piping baseboard and or even radiators for a ground to see which is hot or neutral on the meter read
The Following User Says Thank You to biggles For This Useful Post:
Old 08-14-2013, 08:01 AM   #6
joed's Avatar
Rewards Points: 12,872
Exactly what are you try test for on a two prong receptacle? There is no ground. One prong is not bigger than the other. The best test is to plug in a lamp and see if comes on.
Old 08-14-2013, 08:19 AM   #7
Licensed Pro
Many two prong receptacles are polarized and a check to see if they are wired correctly is sometimes called for. The extension cord method is the most reliable, a "tick tester" may work, but is not as reliable.
Old 08-14-2013, 09:13 AM   #8
Rewards Points: 89
On my receptacle is there is hot smaller slot and a larger slot. I was reading this article....
http://www.structuretech1.com/2009/0...arity-outlets/
and decided it was worth to make sure all my receptacles are wired correctly.
Old 08-14-2013, 04:41 PM   #9
joed's Avatar
OK if you need to test the polarity the extension cord or to the screw holding the cover on if it happens to be grounded.
However the hot should be the smaller slot.
Old 08-14-2013, 04:55 PM   #10
Rewards Points: 89
That's right, the hot is the smaller. Thanks!!!!
changing 3 prong range from hard wired stove Maggiemoos Appliances 5 06-15-2011 06:33 AM
changing 3 prong receptacle to 4 prong WendyS Electrical 12 01-17-2010 08:59 PM
must I change to a 4 prong receptacle WendyS Electrical 7 01-17-2010 05:42 PM
Wire recessed light from a 3 prong receptacle? prc114 Electrical 9 12-22-2009 09:29 AM
2 prong receptacle to 3 prong receptacle Nektopols Electrical 7 12-21-2009 11:03 PM
