How Do I Take Off The Plate To The Circuit Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 05:36 PM   #1
Rewards Points: 184
How do I take off the plate to the circuit box?
It looks like there is an inner plate and an outer place, but I can't seem to get it off with a regular screw drvier.
Any tips?
Some guys were out doing work, and the disconnected a breaker, and I need to reconnect it.
abefroman is offline   Reply With Quote
Old 11-29-2010, 05:42 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Can you post a Pic?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 11-29-2010, 06:47 PM   #3
By plate, do u mean panel cover? What brand it is?
heartlessmcfly is offline   Reply With Quote
Old 11-29-2010, 07:21 PM   #4
joed's Avatar
Rewards Points: 11,500
Panel cover usually has 4 screws to remove and cover comes off.
Old 11-29-2010, 07:52 PM   #5
Chicago, IL
Michael Thomas's Avatar
First question: Do you know how to turn off power to the panel? Safely "reconnecting a circuit breaker" within an energized panelboard is likely beyond the capability of a DIYer who is uncertain how to remove the panel's deadfront.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 11-29-2010, 08:50 PM   #6
Rewards Points: 184
I want to turn the main power off, then take off the panel to make sure the wire is still in there, I didn't see how the last guy left it. Then have a professional reattach the wire.
It has the center screw and then one more like it below, and then the four screws on the corners and two in the middle a long the outside a total of 6 on the outside.
Do I take out the 6 screws on the outside or just the 2?
I got them to turn with a thin flat head, it looks like one of the square screw drives will work too.
Here is it:
Old 11-29-2010, 08:54 PM   #7
" Euro " electrician
frenchelectrican's Avatar
The four corners screws that the one you take them off do NOT take the centre screws out at all leave them alone. { some will have six screws as well depending on size of panel }
A flat screw driver or *2 sqaure screwdriver will work on that one but I know Phillps screw driver may work on that as well.
Once you take the cover off do not touch super large conductor { wire } that is alive all the time.
Merci.
Marc
Old 11-29-2010, 09:16 PM   #8
Rewards Points: 184
Should it be pretty obvious what the last guy did?
Is it common to disconnect a breaker and then leave the wire in the box for reconnection at a later date? Or would he have pull it all the way though the conduit?
Old 11-29-2010, 09:19 PM   #9
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
What were they doing that the breaker needed to be disconnected?
Old 11-29-2010, 09:20 PM   #10
Yeah I do disconnect at the breaker but all it depending on what it have to be done on that circuit.
But I will not reconnect it back until you verify it is properly hook up on the device like switch or receptale etc etc to be on safe side and did the other guy is qualifed to do the electrical work ??
That one of the issue if that person is unqualifed I will not touch it until it check out thru.
Merci.
Marc
Old 11-29-2010, 10:14 PM   #11
Rewards Points: 184
It was shorting at the lift pump.
Old 11-29-2010, 10:15 PM   #12
Rewards Points: 184
Merci.
Marc
Thanks!
open circuit unknown location / voltage leakage fishmanflats Electrical 4 12-23-2009 10:04 PM
Home Theater Dedicated Circuit rjschwar Electrical 20 12-16-2009 01:42 PM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 07:46 PM
Two Different Wire gages on Same Circuit OK? Lovegasoline Electrical 5 12-02-2009 06:00 PM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 09:38 AM
