How Do I Run A 24vdc Solar Attic Vent With 120vac? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-23-2012, 02:35 PM   #1
How do I run a 24vdc solar attic vent with 120vac?
I have a 24vdc / 0.7A solar vent fan in my garage roof and I'd like to be able to run it at night by flipping a standard wall-mount light switch.
I'm thinking of buying a properly rated AC/DC transformer and simply wiring it in parallel with the output from the solar panel. Will this work, or is there a risk of damaging the solar panel, the DC fan motor, or the AC/DC transformer?
Thanks in advance!
czissman is offline   Reply With Quote
Old 03-23-2012, 02:44 PM   #2
joed's Avatar
Rewards Points: 13,712
It will not work. You must disconnect the solar before turning on the line powered DC.
Old 03-23-2012, 02:52 PM   #3
Thanks joed, care to elaborate?
Old 03-23-2012, 02:57 PM   #4
joed's Avatar
You could use a three way switch.
Connect the fan tot he common.
Connect the panel to one traveller screw.
Connect line power 24v to the other traveller screw.
That way only one of the line can be connected at once. Flipping the switch will select between one of the sources. You will still need a switch on line powered adapter unless you want it running 24/7.
Old 03-23-2012, 03:32 PM   #5
Good suggestion joed, but I don't understand why the below won't work. Will it damage something? Are there diodes needed somewhere? A relay or two?
Old 03-23-2012, 04:43 PM   #6
joed's Avatar
Because I don't know what happens if you apply voltage to a solar panel. A solar panel is designed to be a supplier of power not a receiver of power, which it will be at night.
Use a three way switch to select one or the other.
Old 03-23-2012, 07:29 PM   #7
Semi-Pro Electro-Geek
Rewards Points: 2,990
Because I don't know what happens if you apply voltage to a solar panel.[/ATTACH]
You may not know, but it is known: Solar panels are like leaky diodes. They will withstand their rated voltage applied to them while dark, but will leak some current through the panel. When used to charge batteries, a diode is required to prevent the battery from being discharged slowly when the panel is dark. You probably don't need a diode in series with the panel, but it would be a good idea. Your panel may already have one in it.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
zappa (03-24-2012)
Old 03-24-2012, 05:01 PM   #8
So one way to skin this cat with a degree of certainty is to install as my diagram indicates but with diode(s)? Do I need one or two, and do you have a suggestion as to which diode I should buy?
Any other thoughts out there?
Thanks for everyone's replies
Old 03-24-2012, 07:23 PM   #9
You probably don't need the diode since there's no battery to drain. If you want to, install a single diode in series with the positive lead of the solar panel. Any 1A diode should be fine. Radio Shack still carries them. The lowest common voltage rating is 100V, so that won't be a problem. The cathode (marked with a stripe) goes towards the motor, the anode (no stripe) to the solar panel. While you're at it, you might as well install a second diode in series with the 24V adapter so the solar panel doesn't have to backfeed it (there could be some leakage that direction, but probably not much). That way the adapter and the solar panel will be completely isolated from each other, but will both power the fan independently.
Old 03-24-2012, 08:57 PM   #10
Perfect, that's just what I needed, mpoulton... thanks! It's amazing what you can learn in places like this.
The Following User Says Thank You to czissman For This Useful Post:
mpoulton (03-24-2012)
Old 03-24-2012, 10:34 PM   #11
Missouri Bound's Avatar
I would use a dpdt switch. I wouldn't chance any interconnection between the solar panel and xformer.
Do you want it your way or the right way?
Old 03-25-2012, 06:35 AM   #12
Why? Two diodes provides complete isolation between the two sources. It's like a switch, but automatically uses whichever source is providing a higher voltage at the moment.
zappa (03-25-2012)
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Vent pipe is leaking in attic OhmZoned Plumbing 30 01-13-2012 10:32 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
Combining vent pipes in the attic. a4aj Plumbing 5 02-04-2010 11:20 AM
Solar attic fan? stevemr Roofing/Siding 1 06-26-2005 05:35 AM
