How Do I Replace Outdoor Outlet? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-06-2009, 01:03 PM   #1
DIY Expert in Training!
How do I replace outdoor outlet?
I have an outlet that is on an outside wall inside of a covered porch. At some point in the next 2 years the roof is coming down. In addition, currently the box is not even secured. How do I replace this so it's done correctly? Can I simply use a blue box with GFCI? I have access to the inside wall since I am redoing the garage.
Thanks.
gone_fishing is offline   Reply With Quote
Old 01-06-2009, 03:56 PM   #2
It will be easy.
Kill power, test voltage, remove/replace, energize, test.
220/221 is offline   Reply With Quote
Old 01-07-2009, 01:01 PM   #3
Rewards Points: 58
If you mean plastic indoor box when you say blue, it must be changed to an outdoor rated box. They are usually grey and made of metal. You need to reinstall the GFCI and use a matching weatherproof cover and gasket.
Just ask the guy in the store, he will know what you need.
Old 01-07-2009, 01:27 PM   #4
Rewards Points: 506
Send a message via AIM to theatretch85
If the box is installed in the wall (not on the outside surface of the wall) it should be allowed to use a blue box like the op would like to. I assume this is what the op is looking for since he said he had access to the inside wall since he is remodeling his garage. If the box is entirely outside then it must be a weather-rated box like J.V. was talking about. Don't forget that code now requires GFCI outlet and Wet-Location "While-in-use" covers as well.
theatretch85 is offline   Reply With Quote
Old 01-07-2009, 02:24 PM   #5
Funniest.....post.....ever
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 02:54 PM
Carrier 58 PAV-repair vs. replace cczkcb HVAC 8 09-25-2008 01:57 PM
Should I replace all of the plumbing? Pics enclosed? twilightcall Plumbing 15 01-23-2008 09:50 AM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 10:40 AM
