How Do I Power On Ceiling Light Fixtures With Wireless Solution?? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2012, 12:41 PM   #1
Rewards Points: 16
Question
How do I power on ceiling light fixtures with wireless solution??
Hello,
I'm wondering if anybody could help me setup this solution:
My living room does not have any existing ceiling lights so I pretty much rely on using many floor lamps to light up the entire room. I want to completely get rid of all floor lamps in the living room and install new ceiling light fixtures. I just want to flip a switch and turn them on like all my other lights in the rest of my house.
The things is, I don't want to punch holes through my walls to run wires from the attic, drill holes (except to install the ceiling lights), etc. I have heard of wireless electrical power switches and such, however I'm not sure exactly which kinds would be suitable for what I need. Would it be possible to have some kind of wireless device such that include:
1) an receiver/adapter that would plug into an existing electrical receptacle to draw power from
2) a receiver to attach to the ceiling lighting fixture's wires
3) a switch where I can place anywhere on the wall to control these lights.
Could anyone please advise me on a solution, or if there's such a product that can do this?
Many thanks in advance!
webmonkey8 is offline   Reply With Quote
Old 12-17-2012, 01:10 PM   #2
I think you might be a little ahead of the technological curve, in this case. While it is pretty routine to provide wireless "control" of a fixture, I don't believe wireless power transfer is easy to come by at this point.
oberkc is offline   Reply With Quote
Old 12-17-2012, 03:19 PM   #3
TTW
TTW's Avatar
You could always use wiremold.
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-18-2012, 10:04 AM   #4
Rewards Points: 16
oberkc and TTW - thanks for the replies.
That's too bad I'm not able to setup what I've envisioned. Maybe a wiremold then.
Old 12-18-2012, 10:09 AM   #5
Licensed Pro
If you have an accessible attic, you may not need to cut any holes in the wall or ceiling except where the boxes will be installed.
Wireless Light Switch? harding13 Electrical 15 12-23-2015 01:50 PM
Normal light fixtures with suspended ceiling? Scott99999 Electrical 9 09-02-2010 04:44 PM
do all light fixtures need jboxes? simon812 Electrical 4 08-04-2010 07:03 AM
Tying in wiring to existing ceiling light samson115 Electrical 3 11-22-2009 12:12 PM
Replacing Bathroom Light Fixtures, going from one to two. diynewb Electrical 3 11-25-2008 10:16 AM
