A jumper is just a piece of wire that connects two terminals. You can use any size larger than the minimum (specified by the thermostat manufacturer). My thermostat came with several short pieces of #16 wire specifically identified to be used as a jumper, but of course you could use any scrap of #16 you had laying around. Generally want insulated wire so it doesn't short against other wires in the case (you need to strip the last 1/2 inch or so to fit into the connection).
#18 copper wire is usually the size, but I think it is also made in 20 gauge. Hardware stores and the big box stores sell it. A thermostat jumper does not have to be very long. Maybe you could ask a friend or relative for a piece.
In fact, if you have any old phone cable laying around, it will work fine.
Or, if the lead wires going to your t-stat are long enough, and it has unused spares (as most do), cut off about 1.5" of one of those wires and use it.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
