Old 08-26-2008, 01:15 PM   #1
how do i make a lamp
helo i had a lamp wich i did not like because it used a screw in bulb but i wnted a normal one however i suceded but when i plugd it in after a couple of seconds i heard a noise wich sounded like a spark will some one plz help and tell me whats going wrong
dzg123 is offline   Reply With Quote
Old 08-26-2008, 02:12 PM   #2
Moderator
Termite's Avatar
Sounds like you made a bad connection, used an improper part, or generally did something wrong. What type of bulb are you trying to use, and what kind of socket?
A picture is worth a thousand words.
Old 08-26-2008, 02:14 PM   #3
Send a message via AIM to theatretch85
What do you mean by "normal bulb"?
Screw-in bulbs are the "norm", unless your talking about fluorescent bulbs. I assume this must be a table top lamp and not a hanging or ceiling mounted light.
Heard a spark? You probably have a wire shorted to the case of the lamp or another contact. I'd open it up and check all the connections, look for any black marks in the fixture.
theatretch85 is offline   Reply With Quote
Old 08-26-2008, 03:45 PM   #4
arite thanks alot
Old 08-26-2008, 03:52 PM   #5
[IMG]file:///C:/DOCUME%7E1/Admin/LOCALS%7E1/Temp/moz-screenshot-1.jpg[/IMG]it is a bayonet cap and if u type that in in google the sockets will come up
Old 08-26-2008, 04:28 PM   #6
Heheh, I think I would unplug the lamp before I touched anything metal on it.
Fluorescent lamp flickering Ash Electrical 11 08-03-2008 08:35 PM
electric wiring for fluorescent lamp toronbolo Electrical 3 03-24-2008 01:16 PM
Using a european lamp in the States mattlima Electrical 3 03-16-2008 09:12 PM
want to make ceiling light fixture into plug-in lamp Cahill_Main Electrical 8 01-31-2008 04:55 PM
Do canned lights overheat? Not Sure Electrical 14 12-27-2006 08:44 AM
