How Do I Install Outdoor Junction Box. - Electrical - DIY Chatroom Home Improvement Forum
Old 09-07-2010, 10:36 PM   #1
How do I install Outdoor Junction Box.
I am running an new circuit to supply 2 new runs of 110volt lines... I already ran the lines using the UF outdoor cable 21 inches under ground.... and under my new patio. I have the runs come up conduit nex to the house. what type of box do i use to make the junction of the 2... dont want a outlet here just a junction... I am having trouble finding the right box .. I THINK? I found a plastic carlon weather proof box to accomodate my 2 runs electrical (inside conduit). but there is no hole in the back to go into my house. can i drill a hole and hook conduit (run this into my house) then caulk it? Is this code? whats code and can u give me suggestions. also can i run romex from in house just to the box to connect to the outside UF cable runs?
thanks.
luweee is offline   Reply With Quote
Old 09-08-2010, 12:03 AM   #2
" Euro " electrician
frenchelectrican's Avatar
Some of the plastique boxes you can bore the hole in the back which I have done quite few time and when you get done just seal it up with chalk on the top and side but not the bottom { so this way the moisture and water can drain out otherwise it can ruin the wood }
And make sure you have RCD { GFCI } receptales on this circuits .
Yes you can bring the NM from inside to the outside juction box where you change over to UF cable that is not a issue as long you done it properly.
Yes there is blank plastique cover for it many big box store will stock it they should be less than a Euro or so.
Merci.
Marc
Old 09-08-2010, 07:02 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
thanks.
I am having a very hard time visualizing what it is you are doing here. You are describing it like we can see it, yet we cannot.
Can you post a few pics of the areas you are referring to?
Old 09-08-2010, 12:50 PM   #4
ALso can i just use a circuit breaker at the ckt breaker box that is gfci instead of outlets that are gfci?
thanks
Old 09-08-2010, 01:02 PM   #5
Licensed electrician
Rewards Points: 1,876
GFI protection can be from a GFI breaker or receptacle.
You would drill both the back of the box and house in order to connect the cables from inside the house to the junction box. Use a good quality caulk on the top and sides where the box meets the house.
luweee (09-08-2010)
Old 09-08-2010, 01:11 PM   #6
so can i just use ordinary house outlets then? of course inside my weather proof/covered outlet boxes?
Old 09-08-2010, 03:26 PM   #7
With a GFI breaker, yes.
Great pics BTW.
The Following User Says Thank You to Speedy Petey For This Useful Post:
luweee (09-08-2010)
Old 09-08-2010, 09:35 PM   #8
Good photo to show us what ya talking about and yes drill a hole back of the plastique box which I have done pretty often and just make sure you seal the top and side but not much on the bottom { you will need to keep it open some way to keep the mositure drain out }
For the RCD { GFCI } you can have it either receptale or breaker location.
Merci.
Marc
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 05:42 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 08:49 PM
How to install resilient channel on ceiling Bcoleman6 Building & Construction 1 08-22-2008 02:29 PM
Fiberock install STUPID Flooring 5 10-16-2007 06:29 PM
