How Do I Ground Again? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-13-2012, 06:16 PM   #16
Resi EC
Rewards Points: 252
Very good pictures. You said they're working, then the need for us is none.
The only thing that I see is the way the wire goes around the left screw in picture #3, but as long as it's tight I probably would not change it.( just be careful it does not loosen when re-installing the switch.
Gac66610 is offline   Reply With Quote
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 09:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 09:40 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 05:55 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 04:26 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 03:59 AM
