-   -   How do I ground again? (http://www.diychatroom.com/f18/how-do-i-ground-again-156424/)
NewbornZyntax 09-10-2012 03:07 PM
Hey, had an Electricity class back in high school but it's been so long I don't remember how to fix my problem (or if I can fix it even).
I broke a light switch(es) in my apartment, so I went out and bought a new one to replace it. But when I was unscrewing the old switches I pulled too hard on one of the ground wires and it broke out from wherever it was connected.
What I was wondering was, what can I connect the ground wire so that both switches work?
Here is the picture below.
http://i193.photobucket.com/albums/z...23321/lala.jpg
Switch to "SA" broke off. So I replaced switches. Reconnecting "SA" was fine but the ground wire for "SB" broke off from somewhere. So what should I do with the wire at "G1"? Would it be alright if I connected it to "G2"? What about connecting the wire at "G1" to "G3"? If those methods don't work then what else can I do?
Any help would be appreciated, thanks.
Gac66610 09-10-2012 05:19 PM
The black feed, is fed through the switch from point g1 to g2. The black wire appears to have come off another screw, is there another switch in the box?
The green screw is the only ground on the switch, is there a bare wire hanging out of the box? If so it ties to the green screw.
That's a good picture of the switch, do you have one of the box?
dmxtothemax 09-10-2012 08:56 PM
The switchs should work reguardless of where the ground wire is !
It might not be code complient, but it should still work.
Sorry to nit pick !
It looks like SB & G1 are switch one.
SA & G2 are switch two.
G3 looks like the ground.
The SB wire that broke off is not a ground wire,
It is either the hot supply for that light,
Or its the switched supply for that light.
A quick test with a tester will tell you which one it is.
If it remains live reguardless of switch position then its the hot supply.
If not, its probably the switched supply to light.
jbfan 09-10-2012 08:59 PM
Sorry to nit pick !
How so?
If the ground wire is connected to the load side of the switch, tripped breaker.
Gac66610 09-10-2012 09:05 PM
By OP description they are all ground wires
Gac66610 09-10-2012 09:07 PM
Sorry to nit pick !
You can see the brass tab connecting the two visible screws, so that would be the hot side, switch legs on the other side.
DannyT 09-10-2012 10:55 PM
you have a picture of the new switch?
frenchelectrican 09-11-2012 12:08 AM
The G1 and G2 is your actual supply connection and that screw is very dark brass colour or black screw.
The SB is your other black or red conductor to the luminare ( light fixure ) and the SA other black conductor for fan or something else.
The green / hex screw is for ground or bare conductor ( G3 )
Take a photo of the switch box itself we can able indentify it.
Merci,
Marc
oh'mike 09-11-2012 06:17 AM
OP seems confuse with the wording---he is ,perhaps calling the neutral wire a ground---
NewbornZyntax 09-11-2012 01:46 PM
I probably am confused with wording. Was under the impression any black wires were ground.
Anyways, he new switch has been installed, everything is installed normally except for the G1's wire - instead it's just a bare screw doing nothing.
As it is now, both switches work correctly.
I looked inside before, and couldn't find what the pulled out wire was connected to.
I don't have a picture but I can get one if its necessary.
Should I keep it this way? is it safe?
jbfan 09-11-2012 02:32 PM
Take a pic and post it.
frenchelectrican 09-11-2012 11:25 PM
I wrote the underline the standard household electrique system the black is NOT the ground it is a hot conductor the white is netural and bare and green is ground.
On automovitive useage sure the black is negtive so it used as ground but both are not the same function as you expected to see.
And the Household system is AC ( alternating current so it will change from post to neg back and forth many time in a second ) not a DC ( Direct Current as you have in the automotive )
Merci,
Marc
dmxtothemax 09-12-2012 05:31 AM
NOT SO !
Black is not ground when used with white wires in the mains system !
The only time black is ground,
is in low voltage DC systems
where black is used with a red wire.
Please dont confuse this, it is important !
In mains system -
Black is hot.
White is neutral.
Green or bare is earth.
Earth and neutral should be treated as seperate wires.
Even thou they may be interconnectted at some point.
NewbornZyntax 09-13-2012 05:06 PM
Couldn't really get any better pictures. The color of the other wires are yellow.
http://i193.photobucket.com/albums/z...s/IMAG0097.jpg
http://i193.photobucket.com/albums/z...s/IMAG0104.jpg
http://i193.photobucket.com/albums/z...s/IMAG0106.jpg
http://i193.photobucket.com/albums/z...s/IMAG0108.jpg
http://i193.photobucket.com/albums/z...s/IMAG0111.jpg
http://i193.photobucket.com/albums/z...s/IMAG0112.jpg
jbfan 09-13-2012 05:10 PM
Next time turn the power off before removing the switch:laughing:.
Remove the little plastic peices holding the mounting screws to the switch, and the switch will be grounded when you screw it back into the box.
Also, the pic with the two yellow wires, the one on the left needs to be turned around the screw so it tightens when the screw is tightened.
