How Do I Ground A 6/3 Splice To The Juction Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-11-2011, 09:03 AM   #1
How do I ground a 6/3 splice to the juction box?
I am splicing a 6/3 wire for my range. Because I need to move it over another 4 feet. I am putting in a juction box in the basement that is oversize to fit the splices with #6 wire nuts than taping them up so it will not come loose. [My question is how do I ground the splice to the juction box with such a large ground wire?]
davedeb574 is offline   Reply With Quote
Old 06-11-2011, 09:08 AM   #2
Licensed electrician
Rewards Points: 1,598
I would use a lug with a nut and bolt drilled thru the box.
davedeb574 (06-11-2011)
Old 06-11-2011, 09:10 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
The #10 in a 6/3 cable will fit fine under a standard ground screw, which should screw into the threaded hole in the back of the box.
One other thing. Taping the wire nuts will NOT keep them secure or keep them from "falling off".
A properly installed wire nut needs no tape and will not fall off.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
davedeb574 (06-11-2011), electures (06-11-2011)
Old 06-11-2011, 09:30 AM   #4
Thanks pete
I know but I like to tape up every wire nut as an extra safety measure.
Old 06-11-2011, 09:55 AM   #5
Electrician
SD515's Avatar
Rewards Points: 504
No disrespect, but taping a proper wirenut connection affords absolutely no extra safety. A proper installation provides the required safety.
Kyle
The Following 3 Users Say Thank You to SD515 For This Useful Post:
davedeb574 (06-11-2011), electures (06-11-2011), Speedy Petey (06-11-2011)
Old 06-11-2011, 10:03 AM   #6
There is nothing wrong with doing it, but it is NOT necessary if, like I said, the nuts are installed correctly in the first place.
Tape, IMO, services one purpose: Making the installer feel better.
The Following User Says Thank You to Speedy Petey For This Useful Post:
SD515 (06-11-2011)
Old 06-11-2011, 10:10 AM   #7
Rewards Points: 1,010
Wrong, wrong, wrong.
Tape can also cause a hellacious mess and problem if any one needs to un-do the installation at a later date.
If you are bent on causing unnecessary problems in the future, then by all means get out the tape.
They won't keep a loose wire nut from loosening more, and they won't cause a loose wire nut to tighten.
There are no good reasons to tape a wire nut
Anti-wingnut is offline   Reply With Quote
The Following User Says Thank You to Anti-wingnut For This Useful Post:
Old 06-11-2011, 10:15 AM   #8
OK, OK. Let me re-phrase.
"Tape, IMO, services one positive purpose: ...."
Old 06-11-2011, 10:20 AM   #9
Electrician
SD515's Avatar
Rewards Points: 504
To keep the dust mites out ?
Kyle
Old 06-11-2011, 10:32 AM   #10
To make 3M more money? That is if the good stuff is used.
Old 06-11-2011, 10:37 AM   #11
OK, now you guys are getting annoying.
Old 06-11-2011, 10:54 AM   #12
thanks to all the replys
Thank you for all your replys. It will help me with my honey do list for today. Sorry if the electrical tape created an issue for everyone, I know everyone has there reasons I will listen to them all. Thank you!
Old 06-11-2011, 11:30 AM   #13
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Taping a wirenut is like driving a ground rod at a pool. Not necessary.
electures is offline   Reply With Quote
The Following 3 Users Say Thank You to electures For This Useful Post:
davedeb574 (06-11-2011), SD515 (06-11-2011), Speedy Petey (06-11-2011)
How to connect ground wires? Iva Electrical 3 10-29-2010 12:13 PM
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 08:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
sub panel ground and neutral daddyrabbit Electrical 3 01-29-2010 06:49 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 04:55 PM
