-   -   How do I ground a 6/3 splice to the juction box? (http://www.diychatroom.com/f18/how-do-i-ground-6-3-splice-juction-box-107338/)
davedeb574 06-11-2011 10:03 AM
I am splicing a 6/3 wire for my range. Because I need to move it over another 4 feet. I am putting in a juction box in the basement that is oversize to fit the splices with #6 wire nuts than taping them up so it will not come loose. [My question is how do I ground the splice to the juction box with such a large ground wire?]
Jim Port 06-11-2011 10:08 AM
I would use a lug with a nut and bolt drilled thru the box.
Speedy Petey 06-11-2011 10:10 AM
The #10 in a 6/3 cable will fit fine under a standard ground screw, which should screw into the threaded hole in the back of the box.
One other thing. Taping the wire nuts will NOT keep them secure or keep them from "falling off".
A properly installed wire nut needs no tape and will not fall off.
davedeb574 06-11-2011 10:30 AM
Thanks pete
I know but I like to tape up every wire nut as an extra safety measure.
SD515 06-11-2011 10:55 AM
No disrespect, but taping a proper wirenut connection affords absolutely no extra safety. A proper installation provides the required safety.
Speedy Petey 06-11-2011 11:03 AM
There is nothing wrong with doing it, but it is NOT necessary if, like I said, the nuts are installed correctly in the first place.
Tape, IMO, services one purpose: Making the installer feel better.
Anti-wingnut 06-11-2011 11:10 AM
Wrong, wrong, wrong.
Tape can also cause a hellacious mess and problem if any one needs to un-do the installation at a later date.
If you are bent on causing unnecessary problems in the future, then by all means get out the tape.
They won't keep a loose wire nut from loosening more, and they won't cause a loose wire nut to tighten.
There are no good reasons to tape a wire nut
Speedy Petey 06-11-2011 11:15 AM
:laughing: :laughing:
OK, OK. Let me re-phrase.
"Tape, IMO, services one positive purpose: ...."
SD515 06-11-2011 11:20 AM
To keep the dust mites out ? :huh:
Jim Port 06-11-2011 11:32 AM
To make 3M more money? That is if the good stuff is used.
Speedy Petey 06-11-2011 11:37 AM
OK, now you guys are getting annoying.
davedeb574 06-11-2011 11:54 AM
thanks to all the replys
Thank you for all your replys. It will help me with my honey do list for today. Sorry if the electrical tape created an issue for everyone, I know everyone has there reasons I will listen to them all. Thank you!
electures 06-11-2011 12:30 PM
Taping a wirenut is like driving a ground rod at a pool. Not necessary.
