How Do I Connect These Two Sets Of Wires? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-27-2012, 05:01 PM   #1
Ummmm...
Shpigford's Avatar
Question
How do I connect these two sets of wires?
Here's what I'm working with:
What I need to do is connect these two sets of wires. As far as I can tell, the only "hot" wire is the red one.
We're removing a light switch and need to connect the two sets of wires that were connected to the switch.
Before I removed the switch, the white wires were tied off to each other (not connected to the switch at all), the black wires were on the same pole and the red was on a pole of its own.
I tried connecting white-to-white, black-to-black and left red own its own and everything seemed to work fine (as far as other things on the same circuit), but wanted to make sure that's what I should do first before I made it "official."
Shpigford is offline   Reply With Quote
Old 05-27-2012, 05:06 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
That used to be three way switch, if you flip the other switch, you will notice the "red" wire will not have power anymore, but the black wire from that same cable will, to answer your question though, cap the red, tie the blacks together, tie the whites together... the light should still operate from the other switch.
You can only install a blank plate mind you, you can't bury that box....
Old 05-27-2012, 05:08 PM   #3
Rewards Points: 1,542
Normally, to remove a two terminal switch (two screw switch) completely you combine all the wires on one switch terminal with all the wires on the other switch terminal. This makes the "thing" controlled by the switch permanently energized.
Technically a switch with two poles has two pairs (sometimes two triplets) of terminals with one hot wire on each pair (or triplet). Do not combine wires from one pair (or triplet) with wires from the other pair (or triplet) without some extra research about where the wires go.
What did the switch control?
Old 05-27-2012, 05:21 PM   #4
Ummmm...
Shpigford's Avatar
A set of light sconces in a bedroom.
Old 05-27-2012, 06:25 PM   #5
joed's Avatar
Rewards Points: 13,354
No three way that I see from the description.
The black is the power in and out to another device so they need to be connected together.
The white are the neutral. Connect them together.
The grounds all connect together.
The red was the switched wire to the fixture. What happened to the fixture? If it is still there and you want is permanently on then connect the red to the blacks. If the fixture is gone and you don't have anything to switch then cap the red and leave it.
Old 05-27-2012, 06:29 PM   #6
E2 Electrician
The op stated the only "hot" conductor was red, so I just went with 3way.... who knows... theses types of questions are almost impossible to answer without asking a million questions....
-edit, ahhh... after re-reading, I see what you mean.
How do you connect tiny 12 volt wires together? kmc Electrical 8 05-27-2012 10:39 PM
How to connect ground wires? Iva Electrical 3 10-29-2010 12:13 PM
Three hot wires coming into a receptacle? Jeff DIY Electrical 10 10-07-2009 01:35 PM
Adding additional outlet. Pigtail four sets of wires? svanhess Electrical 5 07-12-2009 10:27 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
