How Do I Connect Spade Connectors? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-31-2014, 04:08 PM   #1
Rewards Points: 129
How do I connect spade connectors?
I stick the wire into the hole, and then what?
Do I try to crush narrow middle the neck part?
The plastic sheath doesn't come off, so solder is not an option.
Mathlete is offline   Reply With Quote
Old 05-31-2014, 04:11 PM   #2
Licensed electrician
Rewards Points: 1,622
They get crimped using crimping pliers or a crimp tool.
Old 05-31-2014, 04:16 PM   #3
Master Electrician
Rewards Points: 3,870
I use them on stranded wire only.
brric is online now   Reply With Quote
Old 05-31-2014, 04:21 PM   #4
Rewards Points: 6,652
Mainly for stranded wire. Solid is a little harder to crimp them on. The crimpers are sold in the same aisle. You can also order the tool through partsexpress.com.
I got smart and went to Harbor Freight and picked up a bulk set of different crimp connectors. Then went to Parts Express and ordered extras, along with Waterproof connectors to have when I need them.
Old 05-31-2014, 04:22 PM   #5
The wire also needs to be stripped before crimping.
Old 05-31-2014, 04:40 PM   #6
Rewards Points: 13,712
What is it your really trying to do?
Huge difference in trying to wire up a boat and trying to crimp an 0/ main connection.
Old 05-31-2014, 04:42 PM   #7
Rewards Points: 129
Which part of this tool do I use?
Old 05-31-2014, 04:45 PM   #8
Strippers are close to the handles, the crimp is on the nose of the tool.
Old 06-01-2014, 08:47 AM   #9
Rewards Points: 129
I crushed the circular tube the wire sits in, but it still doesn't feel totally secure.
Old 06-01-2014, 09:17 AM   #10
Sure your using the right size connector for the size wire your trying to use?
See how there color coded according to wire size.
Also notice the color codes on the crimper for what color connector you have.
Wire should just barely slip into the connector.
What pipe is this? can I connect abs to it? oregondiy Plumbing 3 04-04-2011 07:33 AM
Push-in Connectors i_need_help Electrical 13 02-26-2011 08:33 AM
compressing RCA male connectors onto RG-6 cable amakarevic Electrical 0 01-03-2011 02:49 PM
Push in connectors vs. wire nuts sanny651 Electrical 5 02-17-2010 08:26 PM
Adding a phone line to an older connect point cramsmith General DIY Discussions 3 11-23-2005 11:35 AM
