How Do I add a new 120 Adding a new 120v circuit breaker to box
Originally Posted by Shakespeare
Do i connect it to a lug, or does it automatically receive power when I snap it onto the bar? I'm running power to a new outside shed that my dad put together. There are terminals for the wires to be hooked up, but I'm having a dilemma with the breaker... any help?
Many residential breakers simply snap in. When you seat the breaker onto the underlying bus, there is now voltage within the breaker on the line side of the contacts. Screw down the hot leg to the load side terminal on the breaker and connect the neutral to the neutral bar (note: I'm assuming that this is NOT a GFCI breaker as the neutral connection is just a skotch different than described above in that case).
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves,"You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." - George Carlin
