How To Disconnect A Weird Looking Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 07-07-2011, 06:23 PM   #1
How to disconnect a weird looking wire
I'm renovating my Kitchen, and my stove is connected in such a way
that I'm not sure how to unplug, I added pictures that might explain it better.
http://i.imgur.com/kJu0M.jpg
http://i.imgur.com/2cxCd.jpg
I would like to either disconnect it, or make it longer.
p.s.
I live in Germany, if it matters.
jojojo2 is offline   Reply With Quote
Old 07-07-2011, 06:50 PM   #2
Rewards Points: 1,596
It matters.
bob22 is offline   Reply With Quote
Old 07-07-2011, 08:03 PM   #3
Mad Scientist
Okay, I'll bite. It looks like your stove isn't "plugged in" but rather hardwired. I think that first picture shows a junction box where the stove wires are spliced to your house wires. That is the extent of my knowledge I'm afraid. Most of us here typically only deal with USA wiring methods. Except for frenchelectrician, who may be able to give you a more helpful answer later.
McSteve is offline   Reply With Quote
The Following User Says Thank You to McSteve For This Useful Post:
frenchelectrican (07-07-2011)
Old 07-07-2011, 09:04 PM   #4
Electrical Contractor
kbsparky's Avatar
Gas stove?
-KB
Old 07-07-2011, 10:17 PM   #5
" Euro " electrician
frenchelectrican's Avatar
You are not too far off from that point and there is two demarkation box as you guys call junction box one at the wall which it will have termail screw to hold the conductors in.
The second location will be at the stove.
However let me warn you most stove I know they useally use in Germany are typically wired for 3 phase { 400 or 415 volts } so you will have to find three pole breaker to turn it off.
Smaller stove will wired up in either way { either single phase or three phase format }
And older wire colour code IIRC they were all black but green with yellow strip is earth.
I doubt that is really old one so you may have reltive modern colour format I will go by IEC colour format
Phase A Brown
Phase B Grey
Phase C Black
Netural Bleu
Earth Green with yellow stripe.
There may other verison show up so expect that.
Merci,
Marc
Old 07-07-2011, 10:18 PM   #6
Originally Posted by kbsparky View Post
Gas stove?
.,,, Electrique.
Merci,
Marc
What type wire to use from transfer switch to outdoor outlet brjl Electrical 32 11-20-2013 08:36 AM
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 06:41 PM
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 08:20 AM
HVAC three wire motor to six wire motor Leo Caproni HVAC 5 10-18-2010 01:23 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
