How To Disconnect A Switch... - Electrical - DIY Chatroom Home Improvement Forum
Old 02-10-2013, 09:29 PM   #1
How to Disconnect a Switch...
I'm not a DIYer, so be gentle.
I have a bathroom fan switch, rather ancient, that incorporates a timer device that no longer functions, but makes a loud, annoying ticking sound 24/7 and I want to stop this. I don't care about the fan, so it doesn't matter if the switch still functions or not. I just want to silence this stupid thing.
I have taken the unit off the wall and found it is hardwired into the building wiring with one black, one red and a white wire. I gather the black is the "hot" and the white is a neutral, but I don't know if the red is a ground or a switch leg or what. Like I said, I'm not a DIYer and I'm certainly no electrician, so I have no idea what's what here. I need to know which wire(s) to disconnect and which to leave connected, if any. Again, I do not want this device to function once I'm done with this, so I don't care whether it works again or not, I just want it to stop functioning. Any idea what each of these wires is and which I should disconnect? I'd also like to not have an electrical fire when I turn the breaker back on.
Gary
GaryR60 is offline   Reply With Quote
Old 02-10-2013, 09:35 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by GaryR60 View Post
I have a bathroom fan switch, rather ancient...
Get THREE wirenuts and a blank plate.
One wirenut onto each of the three wires. Plate on the opening in the wall.
Old 02-10-2013, 10:28 PM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Code requires an exhaust fan in the bath. Just install a single pole switch for on and off control of the fan.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-10-2013, 10:34 PM   #4
Licensed electrician
Rewards Points: 1,456
I too would advise you the keep the fan functional to remove moisture and avoid mold growth.
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 07:25 PM
Disconnect equipment switch agent99 Electrical 7 06-30-2012 12:52 PM
How to disconnect an outlet from a light switch mattjarvinen Electrical 2 08-25-2011 11:53 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
