-   -   How to disconnect an outlet from a light switch (http://www.diychatroom.com/f18/how-disconnect-outlet-light-switch-115281/)
mattjarvinen 08-25-2011 10:28 PM
2 Attachment(s)
I have a light switch in my apartment that controls both the light in the kitchen and power to both sockets of a dual outlet. How do I adjust the wiring so that the outlet is always powered? The wiring box behind the outlet only has two wires going into the outlet, but the wiring box under the light switch has three sets of three wires (black, white, and ground).
cthomson 08-25-2011 11:43 PM
1 Attachment(s)
The plug you have is wired in series with the lights. You need to wire the lights in series with the switch, and the plug in parallel. You need find out which wires are going to the outlet and connect them to the other side of the switch terminal. Here is a schematic kind of. I hope this helps.
frenchelectrican 08-25-2011 11:53 PM
First of all the key word is apartment you will have to talk to the landlord about the situation you have and YOU can NOT modifaction to any wiring to the apartment at all.
The landlord will have to assist you on this matter.
The drawing you posted is complety wrong for this purpose you can not hook up the light in series due the bulbs will become dim or not working at all.
All the standard lights are wired in PARALLEL connection never in series.
The only time you use the series is the switch loop for switch itself that it nothing else.
All the receptales are wired in parallel as well.
And also if you catch the OP mention apartment therefore he have to get ahold of landlord to assist him on that one.
{ there is a state law or codes reguarding about apartments they are pretty strict on them }
Merci,
Marc
