How To Determine 30A Outlet's Voltage? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-08-2011, 03:14 AM   #1
Question
Do I simply need to purchase a multi-thousand dollar voltmeter?
The ones at home depot only go up to 10-20A maximum. The ones on ebay are even worse
I am hoping to plug this HP E7681-63001 PDU into my 30A dryer receptacle and then plug some computers into that - a mini data-center so to speak. But first I need to determine the voltage, because it will determine whether or not I can plug in 7,200 Watts worth of computers (if 240V) or 3,600 Watts worth of computers into one outlet, correct?
darkaspitch is offline   Reply With Quote
Old 05-08-2011, 03:50 AM   #2
Scared Electrician
Saturday Cowboy's Avatar
I'm not gonna touch this one.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 05-08-2011, 03:50 AM   #3
" Euro " electrician
frenchelectrican's Avatar
Typical North Américaine Dryer receptale are wired for 120/240 volts and there is two conferation of three wire and four wire verison and the power strip you set up in the link.,
That if have 4 wire then it is no issue with it due you can able run balnced load without issue.
Can you tell us if you have three or four wire receptale at the dryer location ?
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
darkaspitch (05-08-2011)
Old 05-08-2011, 04:43 AM   #4
An old Tradesmen
Rewards Points: 7,412
If your dryer circuit is 30 amps. You still can't draw 7200 watts continuous..
Old 05-08-2011, 08:02 AM   #5
Rewards Points: 1,514
The ones at home depot only go up to 10-20A maximum. The ones on ebay are even worse ?
The cheapest voltmeter will do. The 10 to 20 amp maximum is for measuring actual current usage or flow (in amperes) which you really do not need to do for this project.
The dryer receptacle has the same 120/240 volts as your breaker panel and the voltage won't change by more than two or three, unless there is a loose connection (a defect) which needs to be fixed before you use the circuit for anything no matter how small.
If the dryer circuit is wired with 10 gauge wire then you can draw two allotments of up to 24 amps (2900 watts) each on a continuous draw basis.
You need to make up a power load center (a kind of subpanel) with a cord and matching plug for the dryer receptacle, and a box with a number of breakers not exceeding 20 amps each, and 120 volt receptacles either in the same box or in additional boxes. Correction, the Power Distribution Unit linked to above is the load center; you don't need to make anything yourself. However, in the U.S. no one standard 15-20 amp receptacle may have access to more than 20 amps so if the PDU doesn't have built in breakers limiting each receptacle to 20 amps then the circuit into which you plug it has to have a 20 or fewer amp breaker.
If the dryer receptacle has only three prongs you will need to ground your load center. This may be done for a portable load center by adding a ground wire from the load center box strung to any known ground. (If you substitute a 4 prong dryer receptacle and the feed cable does not have a ground, then you need to replace the feed cable with one with a 4'th conductor for ground.)
The Following User Says Thank You to AllanJ For This Useful Post:
Old 05-08-2011, 08:16 AM   #6
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
hey everybody; the ebay site linked is a Canadian site and the PDU shown is apparently straight 240 volt (3 wire twist lock receptacle)
are you in Canada darkaspitch? The ebay site you used is the Canadian extension of eBay and I see some receptacles on that strip that look a bit odd compared to US styles.
Regardless, you will not be able to pull 7200 watts continuous. That is the max load available on a 30 amp 240 volt circuit and you will not be able to max it continuously, You need to reduce the load to 80% for a continuous use.
The Following User Says Thank You to nap For This Useful Post:
Old 05-08-2011, 12:45 PM   #7
Electrician
Rewards Points: 794
That looks like a 240V device, I don't see how you would get 120V out of it. Nap the two plugs by themselves look like they are 240V/15A plug, the other plugs look like regular 15A plugs but I don't see how that is possible.
darren is offline   Reply With Quote
Old 05-08-2011, 01:40 PM   #8
Rewards Points: 1,016
The PDU has IEC 60320 output connectors - C13 and C19 - commonly used for computer servers, network equipment, battery backup units, etc. Input is a L6-30p 240v,
ftp://ftp.compaq.com/pub/products/se.../ds_e7681a.pdf
The Following User Says Thank You to vsheetz For This Useful Post:
Old 05-08-2011, 02:32 PM   #9
nap
You talking to me?
nap's Avatar
great. I couldn't find that the other night.
so, unless the OP has the proper plugs on his equipment, that is not going to do him any good.
Old 05-08-2011, 03:59 PM   #10
My impression is he knows the computer side of he project, else he would not even know such devices exist - the power input side is primarily where help is needed.
Old 05-08-2011, 05:42 PM   #11
dmxtothemax's Avatar
Rewards Points: 5,370
Why dont you use a clamp on amp meter ?
such as this -
If you search around you could find a plug in version,
Not too expensive, and the safest way to do it.
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
Old 05-08-2011, 06:08 PM   #12
I don't plan on it... I was just mentioning that is the total amount available.
I was going to plug a voltmeter into the outlets to determine if it was 120 or 240V (or 3,600 or 7,200 watts maximum...)
I plan on only using ~75% continuous load.
Old 05-08-2011, 06:11 PM   #13
...swooooooosh.... (way over my head) but thanks!
Edit: after re-reading, I think I may have got some of it!?
So I can plug a 10A voltmeter into any wall receptacle and it will give me a proper reading?
And basically what you are saying is... that if my entire apartment is 120 volts, then the dryer receptacle is most likely 120 volts as well..?
There are two dryer plugs actually, so I assume it is 120 volts coming out of there... darn.
Old 05-08-2011, 06:12 PM   #14
Most all computer power supplies take c13 females connections. I simply need a few c13 male/female cords to plug in my computer power supplies.
Old 05-08-2011, 06:14 PM   #15
It is indeed a 240V device.
Which is why I need to know if my dryer receptacle is spitting out 120 or 240 volts before I purchase it.
New outlets don't work!! SectumSempra Electrical 30 01-17-2011 10:34 PM
Need to rewire outlets and lights..HELP suboveryde Electrical 1 11-02-2010 06:19 PM
Installing GFCI outlets in old home surdules Electrical 2 10-20-2010 10:22 AM
Outdoor outlets DIY_JC Electrical 8 08-09-2009 07:12 PM
Code issues for witch operated outlets above kitchen cabinets? jcims Electrical 5 03-25-2009 07:28 PM
