Old 09-16-2007, 09:53 PM   #1
how dangers is an ungrounded receptical
i'm sure this question has been answer but i was checking my outlets and found 2 of my outlets with no ground and i want to know how dangers is it and how to repair it any info will help
kenny357 is offline   Reply With Quote
Old 09-16-2007, 10:16 PM   #2
Electrician
Depends on whats getting plugged in, not too many household appliances have a grounded cord anyways, but if you want you can replace the existing 2 wire receptacles with GFI''s...
just reread your post..., Are you receptacles already 3 wire receptacles but missing a ground? or are they 2 wire receptacles?
chris75 is offline   Reply With Quote
Old 09-16-2007, 11:24 PM   #3
jproffer's Avatar
A good start would be to read THIS THREAD. It goes off course a few times, but the information you want is there.
jproffer is offline   Reply With Quote
Old 09-17-2007, 07:50 AM   #4
RippySkippy's Avatar
Have you taken the covers off of some of the 3 prong outlets to verify that they indeed have a ground and were not just swapped out for convenience? If you haven't yet, you should to see what your dealing with.
RippySkippy is offline   Reply With Quote
Old 09-17-2007, 05:01 PM   #5
not many things are getting pluged in, however one of the receptecals is in the bathroom also the receptecals are 3 wire receptecals thanks for the help
Old 09-19-2007, 12:45 PM   #6
J. V.'s Avatar
chris75.....How would a GFCI work without a grounded conductor?
Old 09-19-2007, 12:52 PM   #7
UAW SKILLED TRADES
Stubbie's Avatar
John:
The nec in 2008 is supposed to make all this confusion about grounded,grounding and ground more clear. The term earthing is going to come into play much like or friends in other parts of the world. Long story though....
I'm sure Chris is talking about that green wire in the cord.....
Notice how I ingeniously avoided any word that starts with "Ground---"....
Stubbie
Old 09-19-2007, 01:40 PM   #8
Licensed Pro
It won't work without a groundED conductor (i.e. neutral) but will work just fine without a groundING conductor.
Old 09-19-2007, 08:34 PM   #9
Electrician
Did your question get answered? And I was talking about a grounding conductor... really didnt think it would be an issue on a DIY site...
Old 09-20-2007, 10:18 PM   #10
yes my question was answer. thanks
adding a ground to an ungrounded recepticle SS396 Electrical 41 09-16-2007 05:56 PM
Breaker for Spot light and outlet receptical hgiljr Electrical 4 08-16-2007 02:10 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
install new receptical? starnz Electrical 2 07-21-2006 03:34 PM
Useing 20A receptical in place of a 15a Doug Crf Electrical 7 04-28-2006 09:23 PM
