Old 05-31-2007, 11:01 AM   #1
mt232's Avatar
How to cut old metal cable (BX)
I have a stray BX outlet on my new 2nd floor. the inspector says I can just cut it shorter, and cap it in a box with a plain cover (cut it shorter so its low and out of sight.)
How can I cut it?
Thank you.
mt232 is offline   Reply With Quote
Old 05-31-2007, 07:22 PM   #2
Eibwen
BX can be cut with a hacksaw [course ya gotta remove the wires first] or even a dremel tool with a cutoff wheel.
There is a plastic insert that slips in the cut end when done to protect the wires from the sharp edges. Gotta have that for the inspector.
Then it can be connected to a box and covered with a blank plate.
Sammy is offline   Reply With Quote
Old 06-01-2007, 01:00 AM   #3
UAW SKILLED TRADES
Stubbie's Avatar
You do not have to remove the wires, though using a hacksaw is fine. You do not cut completely through the bx just cut one surface wrap then flex the bx and it will seperate into 2 pieces. Most electricians use a roto cutter by ideal or greenlie.
Stubbie
Old 06-01-2007, 08:39 AM   #4
mt232's Avatar
Great, thanks!
Old 06-01-2007, 08:44 AM   #5
They're all fixer-uppers
J187's Avatar
Yeah, I use the roto cutter too. It works great.
J187 is offline   Reply With Quote
In-Floor Heating Cable Trouble... sootybuttercup Electrical 19 05-07-2010 09:39 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 03:11 AM
