-   -   How to cut old metal cable (BX) (http://www.diychatroom.com/f18/how-cut-old-metal-cable-bx-8840/)
mt232 05-31-2007 11:01 AM
I have a stray BX outlet on my new 2nd floor. the inspector says I can just cut it shorter, and cap it in a box with a plain cover (cut it shorter so its low and out of sight.)
How can I cut it?
Thank you.
Sammy 05-31-2007 07:22 PM
BX can be cut with a hacksaw [course ya gotta remove the wires first] or even a dremel tool with a cutoff wheel.
There is a plastic insert that slips in the cut end when done to protect the wires from the sharp edges. Gotta have that for the inspector.
Then it can be connected to a box and covered with a blank plate.
Stubbie 06-01-2007 01:00 AM
You do not have to remove the wires, though using a hacksaw is fine. You do not cut completely through the bx just cut one surface wrap then flex the bx and it will seperate into 2 pieces. Most electricians use a roto cutter by ideal or greenlie.
Stubbie
http://www.seatekco.com/images/RS-101A-4C2.jpg
mt232 06-01-2007 08:39 AM
Great, thanks!
J187 06-01-2007 08:44 AM
Yeah, I use the roto cutter too. It works great.
