How To Cut Acrylic Light Diffuser Panels - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-13-2012, 10:13 PM   #16
Blade & a Torch
My diffuser was way to brittle, my patience way to short, and my tool-set way too small to perform most of the suggestions already posted.
I was able to heat a blade (box cutter) with a small torch (a big torch lighter); making quick work of cutting along a line.
I metal strait edge below the diffuser helps keep the line strait.
You'll have to develop your cut-and-heat technique as you go.
I went between heating the mid-point of the blade, and plunging the blade into the line; cutting an inch with each plunge (every 3 or 4 seconds).
Edges weren't perfect, yet good enough for my purposes.
Cheers.
fudgeIt is offline   Reply With Quote
Old 08-14-2012, 07:18 AM   #17
Rewards Points: 2,512
That will work
hammerlane is offline   Reply With Quote
Old 07-19-2014, 04:16 PM   #18
Smile
Finally, an effective way to cut acrylic light panels.
Examine the edges of the factory-cut panels. They appear to have been melted. Observing this, I went to Amazon and bought a 25-watt, hot-knife (an electric soldering iron with an X-Acto style knife tip). When the knife is hot, I score on the textured side of the panel through the texture but not all the way through the panel. When the score line cools, I snap it as I would with any other scoring tool. The melted edges of the score line keeps cracks from propagating into the panel, unlike the cold scoring methods. The hot knife is cheap and can be used as a soldering iron/wood-burner. PS: I bought the Walnut Hollow Professional Hot Knife sold by SuperMart on Amazon for $15, free shipping. It comes with two X-Acto knife style blades. The Walnut Hollow Creative Hobby Tool comes with a variety of tips for cutting, soldering and wood burning.
Scottsdale-DIY is offline   Reply With Quote
Old 07-19-2014, 06:17 PM   #19
Pure Genius
Rewards Points: 150
I use an angle grinder with a metal cutting blade to pretty much melt through the lens
Dierte is offline   Reply With Quote
Old 07-19-2014, 08:48 PM   #20
Rewards Points: 1,192
Table saw.
bobelectric is offline   Reply With Quote
Old 07-19-2014, 09:03 PM   #21
Rewards Points: 1,692
I cut this stuff all the time with a table saw. If you have a good sharp fine tooth blade and take your time there are no issues.
No fine tooth available?
reverse the blade
Bob Sanders is offline   Reply With Quote
Old 07-21-2014, 07:01 AM   #22
Rewards Points: 123
I tried cutting acrylic sheets once using the scoring method. I failed. My sheet was too long it was hard having to score many times to get a clean snap.
I then tried a jig saw using a 32tpi blade and slow speed. That was easy. I didn't get any edge melting or cracking. The edge was smooth - much much smoother than the factory edge.
Druidia is online now   Reply With Quote
Tags
cuting plastic , cutting diffuser , cutting thing acrylic , diffuser , light panels
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
Decorative acrylic cabinet door panels..... SandyK General DIY Discussions 1 02-20-2009 04:00 PM
Marmoleum and Nail Polish Remover AnotherDiyNovice Flooring 9 12-28-2008 03:24 AM
