How To Create A Pass Through For Power - Electrical - DIY Chatroom Home Improvement Forum
Old 06-13-2011, 06:19 PM   #1
Rewards Points: 370
How to create a pass through for power
I have my garage as part of my lower floor although it's not heated. Main panel is in the garage. We are having cellulose blown into the garage ceiling and foam into the walls to help with insulation. I realize this makes fishing wire to the panel quite a bit harder.
Any idea's? I was hoping to run one of those datacom low voltage cable pass wall plates and running that into a sort of conduit but I realized it's only for low voltage.
Can I just run two 1 inch metal pipes next to it? Is that within code? I'd have to cap them to start and foam them once in use but I figure it's worth saving the hassle later.
Ideas are appreciated.
MLMIB is offline   Reply With Quote
Old 06-13-2011, 07:17 PM   #2
Missouri Bound's Avatar
What are you planning on running? If you are going to install some cable, then yes you can use a couple of conduits as a "chase" to get you from one space to the other.
Old 06-13-2011, 09:25 PM   #3
Rewards Points: 370
so do these...
http://www.amazon.com/DataComm-45-00...8017912&sr=8-6
only work for low voltage?
what qualifies as conduits? I'm assuming plastic doesn't and only metal would let me make the conduit between the garage and the rest of the house?
Thanks for the help.
Old 06-14-2011, 07:40 AM   #4
Licensed electrician
Rewards Points: 1,874
I would use either EMT or a PVC conduit between the panel and a junction box with a cover at the top.
The inlets that you linked to would still need to have cables fished between the 2 points. The foam would make that difficult. I did not look to see about the LV rating.
Old 06-14-2011, 08:10 AM   #5
Rewards Points: 320
Conduit doesn't have to be metal. There is flex conduit (liquidtight) or the grey pvc, probably others. I'm not an electrician but I believe you need to have your wire secured at the point of entry in to the panel but I would think you also need the conduit secured to the panel. So i'm not sure how you would do that or if you'd still need the wire secured if the conduit they run in is.
autx790 is offline   Reply With Quote
How to pass conduit from one side of a wall to another pick1e Electrical 8 12-04-2010 06:15 PM
kitchen pass through load bearing shann84 Building & Construction 2 01-18-2010 08:45 PM
Installing header for kitchen pass through bpchevyguy Remodeling 32 09-26-2009 12:31 AM
Adding Kitchen pass through to an existing opening? sscott0203 Remodeling 7 12-13-2008 03:17 AM
Where to buy Pass & Seymour Specialty jamiedolan Electrical 6 11-03-2008 11:12 PM
