-   -   How to create a pass through for power (http://www.diychatroom.com/f18/how-create-pass-through-power-107586/)
MLMIB 06-13-2011 06:19 PM
I have my garage as part of my lower floor although it's not heated. Main panel is in the garage. We are having cellulose blown into the garage ceiling and foam into the walls to help with insulation. I realize this makes fishing wire to the panel quite a bit harder.
Any idea's? I was hoping to run one of those datacom low voltage cable pass wall plates and running that into a sort of conduit but I realized it's only for low voltage.
Can I just run two 1 inch metal pipes next to it? Is that within code? I'd have to cap them to start and foam them once in use but I figure it's worth saving the hassle later.
Ideas are appreciated.
Missouri Bound 06-13-2011 07:17 PM
What are you planning on running? If you are going to install some cable, then yes you can use a couple of conduits as a "chase" to get you from one space to the other.
MLMIB 06-13-2011 09:25 PM
so do these...
http://www.amazon.com/DataComm-45-00...8017912&sr=8-6
only work for low voltage?
what qualifies as conduits? I'm assuming plastic doesn't and only metal would let me make the conduit between the garage and the rest of the house?
Thanks for the help.
Jim Port 06-14-2011 07:40 AM
I would use either EMT or a PVC conduit between the panel and a junction box with a cover at the top.
The inlets that you linked to would still need to have cables fished between the 2 points. The foam would make that difficult. I did not look to see about the LV rating.
autx790 06-14-2011 08:10 AM
Conduit doesn't have to be metal. There is flex conduit (liquidtight) or the grey pvc, probably others. I'm not an electrician but I believe you need to have your wire secured at the point of entry in to the panel but I would think you also need the conduit secured to the panel. So i'm not sure how you would do that or if you'd still need the wire secured if the conduit they run in is.
