How To Convert A Pin-base CFL Socket To A Screw Base Socket In Can Light? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-02-2010, 07:37 PM   #1
Question
How to convert a pin-base CFL socket to a screw base socket in can light?
Hi everyone,
I am hoping that someone will be able to help me. Thanks in advance!
I just got this house and the previous owners did a number on the place - although it is only 7 years old. Among other things, I have some electrical issues with the kitchen can lights. I have 10 cans and 3 types of sockets! 7 screws, 2 small pins and 1 large pins. I would like to convert the pin-bases to socket bases so that everything looks the same and used the same CFLs.
1 - can this be done?
2 - do they sell converters/adaptors and where?
Thanks again!
minh is offline   Reply With Quote
Old 09-02-2010, 07:46 PM   #2
I've learned that the pin base lamps (mine) have the transformer built into the fixture
So you are into more then just changing out the socket
Old 09-02-2010, 08:03 PM   #3
Licensed electrician
Rewards Points: 1,486
You don't say your location, but California has an energy regulation called Title 24 that requires lighting in kitchens to be energy efficient. Screw in fluorescent bulbs do not meet this as they could be changed out for regular incandescent bulbs. You may not be allowed to change to a less efficient fixture.
Speedy Petey (09-03-2010)
Old 09-03-2010, 09:31 AM   #4
zpm
yeah, right
California has a bunch of pin heads in Sacramento. They create stupid regulations like this, but its OK that Wal-Mart is open 24x7 and has all their lights on and maybe 2 customers in the store at 3am. You're paying for the electricity so do what you want. Sincerely Yours, A Bitter Over-taxed Over-regulated Citizen.
Honey, does this tool belt make me look FAT?
zpm is offline   Reply With Quote
Old 09-03-2010, 10:47 AM   #5
So you live in CA & haven't heard of the rolling brown-outs ?
In addition on resale the homeowner may be stuck with paying someone to swap out the lights again to meet code
Old 09-03-2010, 11:24 AM   #6
Just call me Andrew
Rewards Points: 1,020
This true for normal fixtures too (as well as recessed)?
I have a fixture I love, but I hate the fluorescent lights that go in it (pin-based socket). Never even thought to try and swap it out...
Andrew
secutanudu is offline   Reply With Quote
Old 09-03-2010, 10:57 PM   #7
" Euro " electrician
frenchelectrican's Avatar
Yeah even a normal surface mounted luminaire some will have factory wired flourscent ballast and pin socket.
But IIRC there is some leeway if you have G10 or G26 base you may change wattage but it will still be flourscent but the ballast will be in the base.
but multi pin base square shape it pretty much delcated. unless you change ballast.
Merci.
Marc
Old 09-03-2010, 11:28 PM   #8
Just call me Andrew
Merci.
Marc
Thanks, Marc.
Is it tough to just remove the ballast and convert it to an incandescent socket?
Andrew
Old 09-04-2010, 04:43 PM   #9
Originally Posted by secutanudu View Post
Thanks, Marc.
Unforetally that is true due there are few items are diffrent between the indentscent and flourscent luminaire especally with recessed luminaires they are diffrent by day and nite especally the indentscent will have termal switch inside the can itself while flourscent verison it kinda toss up depending on manufacter but they will have thermal protection on the ballast itself that is a manitory item.
Merci.
Marc
Old 09-05-2010, 08:35 AM   #10
Just call me Andrew
The one I had in mind is a semi-flush mount fixture, not a recessed...
Andrew
Old 09-06-2010, 12:27 AM   #11
If possible if you can take a photo of it myself or other electricians in this fourm can able indentify if possible to convert or not.
Merci.
Marc
Old 09-06-2010, 07:35 AM   #12
Rewards Points: 1,494
Fixtures are rated for ability to dissipate heat, often expressed as bulb wattage and here it is fluorescent wattage. The fixture as it stands is equipped to accept only a specific bulb (lamp) or maybe a choice of two or three and there might not be a maximum wattage label . If you retrofit the fixture with a screw in socket, there will be a fire hazard if the next homeowner puts in an incandescent bulb even within the maximum stated watts. An incandescent bulb gives off more heat than a fluorescent of the same wattage.
Modifying any fixture voids the UL or other safety rating.
The Following User Says Thank You to AllanJ For This Useful Post:
Tom Struble (09-06-2010)
Light cord to screw in socket adapter? Charger Electrical 11 05-02-2010 06:04 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
Light Socket Won't Hold Light Bulb colhollywood Electrical 3 08-16-2008 08:28 AM
Icicle at base of exterior light -- insulation problem? curls00 General DIY Discussions 1 11-20-2007 10:14 PM
Switching from light socket to plug - stupid question CGofMP Electrical 5 03-25-2005 09:48 PM
