Old 04-04-2011, 06:16 PM   #1
How to convert AAA batteries?
Hi.
Is there way to convert 3 AAA batteries to a thin round lithium battery, in that our son plays with a toy that uses A LOT of AAA batteries and since the product uses 3 AAA's at a time, I thought I would try converting it to a lithium battery instead to see if it saves us a little money.
Thanks for the feedback!
tatums4 is offline   Reply With Quote
Old 04-04-2011, 06:19 PM   #2
the Musigician
DangerMouse's Avatar
It seems to me it'd be easier to get re-chargeable AAAs and a charger?
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 04-04-2011, 06:53 PM   #3
Just pick up some Sony Eneloop rechargeable batteries and a charger.
Dahammer is offline   Reply With Quote
Old 04-04-2011, 07:01 PM   #4
the Musigician
Isn't that what I just said? Brand name should not matter.
DM
Old 04-04-2011, 07:39 PM   #5
STAFF
BigJim's Avatar
DM
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is online now   Reply With Quote
Old 04-04-2011, 07:42 PM   #6
Wire Chewer
Red Squirrel's Avatar
Watch out with rechargeables, they are usually only 1.2 volts instead of 1.5. Some devices wont care, but others will. The more batteries it takes, the bigger difference it will make.
ex: 3x normal AAA @ 1.5 volt = 4.5 volts. 3x rechargeable AAA @ 1.2 volts = 3.6. If you can somehow fit a 4th battery in there by modifying the toy, you could get away with it as it would bring you to 4.8 volts which is slightly over what it needs but should not be too much more. Or if it's easier you could try to convert to AA. They are normally more readily available in bulk packs, and they'll last slightly longer.
Old 04-04-2011, 07:47 PM   #7
First, there is no way that you can convert to the smaller type batteries because the amp hour rating is way to small, lithium or not. Second, the easiest way to convert to lithium batteries for you would be to pick up some AAA lithium batteries. Done.
http://www.amazon.com/AAA-Lithium-Ba.../dp/B000U7MYDE
davido30093 is offline   Reply With Quote
Old 04-04-2011, 07:49 PM   #8
the Musigician
ORRRRR, just do like "I" do and RECHARGE the AAA Alkaline batteries!
Then there's not a problem!
DM
Old 04-04-2011, 07:51 PM   #9
Wire Chewer
DM
Is that actually safe? I've done it before by accident, and it actually works! But I thought it had a chance to explode or something, or is that just a cheap label they put to scare you?
Old 04-04-2011, 07:54 PM   #10
No, it is not safe. They can explode if you charge them too fast, or for too long. They will re-charge for a limited amount for a few times, then they are gone. If you are not sure about the charging rate or charging time, it is best to not do it.
Old 04-04-2011, 07:54 PM   #11
NiMH rechargeable batteries rock. They work in absolutely everything I've tried. It really wouldn't shock me if I found out that all portable electronics were designed for the 1.2V they put out.
The only reasons I'd buy lithium batteries:
1) I needed shelf life. Example might include a flashlight in a glove compartment.
2) I was stuck somewhere needing to use my AA camera and my NiMH batteries had exceeded their useful life. This happened to me.
pyper is offline   Reply With Quote
Old 04-04-2011, 07:54 PM   #12
the Musigician
ummmm, I use a Battery Master which is MADE to recharge alkaline and nicads.... you can get DOZENS of recharges from good (read Duracell or Eveready alkalines) alkaline batteries. It does aa, aaa, c and d cells.... I just wish it did 9v too....
DM
Old 04-04-2011, 07:59 PM   #13
Read the label on your akaline batteries and see if it says that it is safe to recharge them. It does not matter what the maker of the charger says, it matters what the maker of the battery says.
Old 04-04-2011, 08:01 PM   #14
BTW a "real" rechargable battery can be recharged hundreds of times during its normal life cycle.
Old 04-04-2011, 08:14 PM   #15
the Musigician
This thing has recharged hundreds of alkaline batteries with no problems....
DM
Testing Batteries With a Multimeter Kent10 Electrical 17 01-17-2011 09:55 AM
leakage from AAA batteries sweets Electrical 1 07-28-2010 10:54 AM
wiring diagram for hedge trimmer batteries mturner25 Tools 0 06-09-2010 09:22 PM
New batteries in cordless drill won't charge Gyrobob Electrical 6 04-08-2010 12:41 PM
Dead Batteries on power tools pawned Tools 25 11-07-2007 12:11 AM
