How To Connect TM-619H To 12v Dc Water Pump - Electrical - DIY Chatroom Home Improvement Forum
Old 09-05-2013, 07:52 AM   #1
how to connect TM-619H to 12v dc water pump
hi i have problem to connect my TM-619H digital timer to my 12V DC water pump.
i use 12V DC battery to powered my timer.
please help me. tq
jy1764 is offline   Reply With Quote
Old 09-05-2013, 08:36 AM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
wiring diagram
You would hook your power from battery to terminals 1+ and 2 -, hook your pump to 4 + and 5-.
wirenut1110 is offline   Reply With Quote
Old 09-05-2013, 08:48 AM   #3
can you help me to draw the connection from the diagram that i attach
Old 09-05-2013, 12:12 PM   #4
Rewards Points: 510
Assuming the 2 on the left are 1 & 2 and the 2 on the right are 4 & 5.
Old 09-05-2013, 07:10 PM   #5
when i chck the output voltage use multimeter, it give 26 v. it's not have effect to my 12v dc water pump?
Old 09-06-2013, 09:42 AM   #6
Rewards Points: 510
Do you have a TM-619H-4?
Are you using a 12 Volt battery?
Sure you're reading your meter correctly and it's accurate?
If so, I'm not seeing why you would have 26 VDC
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Sump Pump Water Level Lucky000 Plumbing 5 10-02-2010 07:05 AM
Yet another sump pump / pit question SeanFlynn Plumbing 0 01-24-2010 01:07 PM
