How To Connect Switch To GFCI Breaker? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-28-2008, 07:54 PM   #1
Question
How to connect switch to GFCI breaker?
I have installed a bathroom vent fan above the shower/tub and need to make sure I connect this to a GFCI breaker. The vanity light and bathroom fan are currently connect to a switch that is NOT on a GFCI breaker. There is a outlet in the bathroom that IS on a GFCI circuit breaker. I know next to nothing about electrical work but it seems like the simple solution would be to somehow get the switch that controls the vanity light and bathroom fan to also be connected to the GFCI circuit breaker. I have no idea why this was not done in the first place. All wiring is 14/2. Any ideas are appreciated. Thanks.
firemanter is offline   Reply With Quote
Old 10-28-2008, 07:59 PM   #2
dSilanskas's Avatar
They do sell switches that have a GFCI protection built inside of them. Very easy to install just go to a electrical store and ask for a GFCI switch!
dSilanskas is offline   Reply With Quote
Old 10-28-2008, 08:04 PM   #3
That is awesome. Thanks. Do they make GFCI switches that look normal (except for the test and reset buttons)? All the ones I find are receptacle/switch combos or look nothing like a normal switch.
Old 10-28-2008, 08:46 PM   #4
dSilanskas's Avatar
The only ones that I have seen look like GFCI's just a switch on the top and a test reset button on the bottom. If you dont want that look than yeah a GFCI breaker is the best bet
Tags
bathroom , circuit breakers , gfci
New GFCI Breaker Tripping w/ 3-way Flourescents BigJimmy Electrical 8 12-29-2008 03:29 PM
Switch trips Breaker pvrio Electrical 4 09-21-2008 05:53 PM
GFCI switch to control outside outlets billgeo Electrical 14 09-09-2008 12:09 AM
GFCI light switch trips once per night ???? mw6263 Electrical 11 07-25-2008 12:05 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 09:59 PM
